HEY GUYS,
i have an r32 gtr a while ago the alternator died by over charging, now the wipers seem to stay on or blow the fuse?? as well as the aircon/heater only works on flat out and demister?? and passager side door stays lock 24/7?? any help would be great i did search but found nothing
thanks
https://www.sau.com.au/forums/topic/325999-weird-electrical-problems/
Rus
I'd start by checking All fuses (3 lots), the fuseable links (best done with a multimeter),
I fear if the overcharging was bad some of the 'black' boxes throughout the car might have issues though
OR
you may have some melted wires under the dash (check round the firewall where space is tight and the heat gets traped, behind the stereo/aircon may be worth a look to)
couple of Q's
does the car run OK, ie is the ECU OK
is there anything you can do to make the wipers either:- come on, or blow the fuse. Or is it random
cheers bundy
checked all the fuseable links i could find pulled out dash and it all looks fine
car runs fine no problems at all
as for the wipers the stay on constantly as soon as you start the car and will blow the fuse after 2 or so minutes
thanks
Edited by RUSSMUSS
Did you change the alternator yourself? Or did you use an autoelec?
If you used a sparkie, and all this happened straight afterwards, then...... !!!
ECUs can get touchy like bundy said.
This is a remote chance, but the same thing happened to a guy's car in Canada. When winter cold set in, the mice started to eat not just the birdseed that was stored in his garage, but also the wiring that fed his central heating + his car. No mice in your garage?
Nah! See the sparkie! Although time = $$$, so a mate who's an autoelec?
And when it's all fixed, check out the Event, "R32 GT-R 21st Birthday" and come along eh?
Rus
I'd start with the wipers (cheaper) and swap the brain (black box), I think its under the dash
if that works replace the aircon controls in the dash
sounds like it might be an $$$ journey though
bundy
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
