Front ie transfer case to front diff is the same.
Gearbox to diff: rear section is the same across all GTR's and Stagea, but the front ie where it connects to gearbox is different on the stagea. 32r and 33r are same, 34r is another length, stagea another (the longest of all)
32r, 33r and stagea all have the same front shaft. 34 is different length.
It *might* be different for autos though. IIRC, a few people have had issues swapping, I think it was 4-bolt on one and 6-bolt on the other - can't remember exactly.
Like I said, though, I'm not sure...
he was auto... now manny.... y rubz?? ull need to put out decent power b4 u go snapping then :D jokes!
serious note.. the autos were good for 250 awkw.... if tangles hasnt snapped one im sure your not going to... hes done a fair bit of mallala time on his i believe.
Edited by chef_stagea
Getting the front driveshafts. Not worried about the rears. Accumulating some bits and ensuring my front end is A1 for the AWDTC that I've entered into. :)
Thanks for confirming fellas :D
Is it really going to be worth it? If Tangles hasnt snapped any with the power hes making and been on the track im sure yours wouldnt. Couldnt spend the cash elsewhere like swaybars or rear strut-brace or something roo?
  • 1 month later...
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
