hey
just bought a set of volk gtc's for my r33 gtr. got them home and realised i need a set of different nuts for them.
where am i able to find these specail nuts, and hub rings for them and is there anything else i may need to fit them?
thanks
https://www.sau.com.au/forums/topic/326042-gt-cs-on-a-gtr/
youll be the second silver 33r with gt-c's in adelaide then (havent seen any others yet). heres how dope theyll look once you get em on...
the standard volk nuts mine came with are 12x1.25mm internal hex drive nuts. youd probably be looking around the 250-300 mark for a set. on the other hand if you already have some nuts, see if a place like wheelworx can machine them down to correct diameter.
https://www.sau.com.au/forums/topic/326042-gt-cs-on-a-gtr/#findComment-5310872
The profile looks too high on the front..
https://www.sau.com.au/forums/topic/326042-gt-cs-on-a-gtr/#findComment-5311435
That's coz it is. Took that pic just after I put the coilovers in ans the backs were too low. Ideally I wouldve lowered the fronts to match but that would make it too impractical as a daily. Since that pic ice raised the rears so the stance is even now
https://www.sau.com.au/forums/topic/326042-gt-cs-on-a-gtr/#findComment-5311747
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
