hey
just bought a set of volk gtc's for my r33 gtr. got them home and realised i need a set of different nuts for them.
where am i able to find these specail nuts, and hub rings for them and is there anything else i may need to fit them?
thanks
https://www.sau.com.au/forums/topic/326042-gt-cs-on-a-gtr/
youll be the second silver 33r with gt-c's in adelaide then (havent seen any others yet). heres how dope theyll look once you get em on...
the standard volk nuts mine came with are 12x1.25mm internal hex drive nuts. youd probably be looking around the 250-300 mark for a set. on the other hand if you already have some nuts, see if a place like wheelworx can machine them down to correct diameter.
https://www.sau.com.au/forums/topic/326042-gt-cs-on-a-gtr/#findComment-5310872
The profile looks too high on the front..
https://www.sau.com.au/forums/topic/326042-gt-cs-on-a-gtr/#findComment-5311435
That's coz it is. Took that pic just after I put the coilovers in ans the backs were too low. Ideally I wouldve lowered the fronts to match but that would make it too impractical as a daily. Since that pic ice raised the rears so the stance is even now
https://www.sau.com.au/forums/topic/326042-gt-cs-on-a-gtr/#findComment-5311747
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
