hi guys, she lives.
spec is as below with power figures
rb30 block
fully home ported rb26 head
1.6mm cometic h/g
cp forged slugs 8.3.1
spool gen 3 rods
tomei oil pump
ati 1000bhp front damper
acl race bearings
hks step 2 cams 272/in 10.2mm lift 280/ex 10.2mm lift
os giken r4c clutch
gt4094r turbo
6 boost manifold 50mm turbosmart gate 4" dump + 2"screamer
std box, with giken centre plate and cryo treated gears
power is at the hubs
470kw,s @ all 4 wheels @ 1.5 bar
530lbs @ all 4 @ 6600rpm
full boost by 4300rpm
will post graphs and a small dyno clip soon.
car was dyno on a hub dyno in 50degree temps, its warm here at the moment.
Edited by rockabilly
https://www.sau.com.au/forums/topic/326066-my-rb2630-lives/
well she,s back on the road, new bottom end, spool rods, tomei oil pump,cheers rick @ endless, new at 1000bhp damper,cometic 1.6mm h/g, hks step 2 cams, fully ported head by me.lol.
graphs and a little dyno clip of the old girl winding up..
thanks th garth/mark @ mgt for all there help in installing and mapping the link g4, superb ecu for driveability, not may cars tickover so smooth with this power..
figures are at the hubs.
640bhp @ 1.5bar boost
530 lbs @ 6600rpm.
bernie.
https://www.sau.com.au/forums/topic/326066-my-rb2630-lives/#findComment-5309372
great to hear bernie :D
what boost level are u planning to run or u sticking with 1.5bar?
oh & what is that thing sitting above the intake lol - when i 1st looked at your clip i initially thought it was a pisstake as it looks like a MASSIVE turbine!
https://www.sau.com.au/forums/topic/326066-my-rb2630-lives/#findComment-5309420
hi marko, we tried higher boost but made no more power just slightly more torque?. but temps in the booth were 50deg as it was 30 deg outside, the extra turbo was to keep the plenum below 50degrees on the runs..lol. maybe because i am still on the original plenum its restricting it.. but it goes well.lol..very well....so for the moment leave as is.. just to add, the motor had done 45 miles on 10/40w semi synth oil, then dropped and fully synth added and dynoed...done 160 miles now ..........
https://www.sau.com.au/forums/topic/326066-my-rb2630-lives/#findComment-5310545
ive always wondered what an aftermarket single throttle body intake plenum would make in terms of gain...does anyone have this data (i.e. before & after test)?
im also using the factory intake plenum :)
https://www.sau.com.au/forums/topic/326066-my-rb2630-lives/#findComment-5310812
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
