http://www.google.com/search?q=Grid+Ts+Dancer
5 results down:
http://www.skylinesaustralia.com/forums/R3...cer-t35275.html
First post:
There are 2 buttons on the controller, a square on/off button (to swtich between the factory auto 4WD and the controller) and a round button that allows selection between 4WD and FR (rear wheel drive)
Search more, post less :)
Yes i have read that but that is for the older Grid dancer, the new one has 2 square buttons a display and a knob.
Regards!
/Pontus
If you google the full and correct title you will get better results (can the supplier not help you?).
Looking at a picture there are two square buttons, a round knob and an LED display. Using only my powers of deduction (!!!) I would guess that one square button turns the unit on and the other square button returns the car to the control of the Attessa computer. Turning the round knob should produce numbers on the LED display ranging fom 0 to 50 indicating that you are locking in that percentage of drive to the front wheels.
Have a play and see if I am right - (I am just guesing here!)
also guessing....but I reckon that is all right except the bold bit. Unless it replaces the factory attessa controller it can only "bend" the input signals like everything else, which means it is probably more like "0 to 50 indicating how much more front drive you are getting than normal" as opposed to a fixed %
I saw claims on the interweb that it creates fixed front torque, but that is not possible with the factory attessa computer.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
