I been tuning a built RB25DET at a country next door, Engine is of stock configuration with built internals with a big turbo charger. Bigger then T04Z and smaller then 42r...
We need to rev this thing to 8500rpm to get things happening.....
I have advised the obvious, Balancer, Oil Pump.... But we need to come up with a decent head build.
Head porting is a issue. No one here will be able to port a head and get good proven results unless its a big F off fluke, and we are not going to take these chances. Because lets face it.. Around these parts of the world... To get a spare RB25 head? it will have to be imported from Japan and the cost of that would be of 5 heads back in Australia IF we are lucky.
We want a decent head build combo that will give us revs, does not matter if we have to go solids ors 280 cams. Customer wants a fast RB25 and he knows he needs to spend some coin to get it.
SO... What do we need to do to a RB25DET head to spin it to 8200 - 8500 rpm.
Please, No amature comments, if you have not done this before and have no experience then do not post crap in this thread. *nice tone of voice*
Yes... I have searched.
Cheers
https://www.sau.com.au/forums/topic/326093-rb25det-8500-rpm/
I rev'd the stock head to 8500rpm, and now that it's ported, bigger cams and Tomei valve springs we go to 9000rpm. Had this with a TO4Z running 600rwhp. Still using stock hydraulic lifters, had considered the swap to solids, but was alot of extra $$$.
hks 256/264 h/d valve springs revs 8500 rpm all day and ive done 30,000 km on it with 100 passes at the drags its a good combo.
jim at crd tuned the car he wanted to go past the 8500 rpm cos it was still was making power but i dint want to.
Edited by WARLORD
Decent cam profile and springs is the key and it will be fine, i prefer to use lighter retainers but they are $850 for a kit which includes titanium retainers and springs. Lifters obviously need to be healthy to start with.
I have a 25 head here atm which has been CNC ported and has camtech 272's and the HD springs and Ti retainer kit 9k rev limit, its a relatively new combo so i will let you know how it holds up..
on a side not how is Georgia treating you? i havent had much of a chance to chat with the shop being so busy... i apologise.
yeah good mate! :)
Do you think 264 with 9.3 mm lift and some spings should do the job nicely? what kind of oil pump do you suggest
It is a GT37 turbo, and it suffers from compressor surge a fair bit.
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
