I noticed you were selling the boot lock from an R34, does that mean you have a boot that is just going to waste?
Im looking for the Boot Lid Brake Light, or atleast the housing for it as I can arrange my own bulbs.
Thanks.
heres whats left....
1 x r34 xenon headlight with gassed bulbs L/H side (broken clips) $130
2 x r33 GTR front pipes (good nick) $120 (standard)
1 x r34 boot lock $20 ono (working order)
1x r33 gtst front R/H shock + spring (unknown condition) $30
2x orange front bar indicators, in good nick $30
2x r34 gtr door trims (crappy cond) MAKE OFFER
1x standard rb26 r33 gtr computer (make offer)
1x r33 gtr coilpack ignitor module $130
1x r33gtr airflow meters (perfect condition) (make offer)
2x complete child seat compliance brackets (all bolts nd shiz) make offer
1x r33 gtst hyper D' coilovers... unsure of spring rates but there height and damper adjustable (only rear available) slight knock in the left one... needs new pillow bush or sumthing...(make offer)
R34 RB25 neo N/A full exhaust extractor back, comes with extractor + cat + twin tip + all pipings etc $200 ono
toyota supra airbox, full twin box and air intake included $200
r34 N/A standard rear traction brackets + upper and lower arms etc... (make offer)
2x r34 water dispersers (the things that go around the window so you can have your window open on a wet day) (make offer)
2x 300zx rear rims painted spray can black (1 had roadworthy tyre, other full rooted) (make offer)
1x 49cc petrol motor scooter.... max 5 hours play time $160ono
vl radiator $10 decent condition when removed
vl cluster $5 no rev counter, it's the clock 1, I'll spin the km if u want
worn monza gearnob $1 with any purchase
r33 gtr tomei fuel pump unknown condition $20 was removed to diagnose a bad fuel problem, unsure if it's fu*kt or not
hi mate thanx alot.. i would like to buy the headlight asap for my r34
my email is [email protected]
please send me ur contact phone number and il call u and lets arrange the meet up
thanx bro...
cheers
  • 3 weeks later...
hey guys just merging threads
MERCEDES BENZ W203 19" AMG (very rare + expensive) WILL FIT FORD AND SKYLINE they are in mint/exceptional... not even a touch of a scratch on em...
they are...
2x 19x8.5 (front)
2x 19x9.5 (rear)
rims include 4x center caps+ 4x chrome valves +20x studs
the wheels have never been fitted with a tyre
offset +35 stud patter 5x114.3 (WHEN USING NUTS)
stud pattern when using wheel studs 5x 112
$1100 ono
2 x rb26 cam covers $60 for both or $40 for 1 (good for a paint or a chrome)
2 x cadence speaker $10
2X pioneer 6x9 $30
1x MINES ECU RB26 ( make offer) SOLD
2x r33gtr airflow meters (perfect condition) (make offer)
1x complete child seat compliance brackets (all bolts nd shiz) make offer
1x pair of r33 gtst rear shocks + springs complete with tops... good eye bushes etc .... no nocks or nothing... (make offer)
1x SR20de in peices all bolts etc complete minus coilpacks, alternator, powersteering pump
1x SR20de loom (no chops) full loom
1x S13 turbo brakes inc calipers and disks + lines (front only)
1x s13 manual tailshaft
1x s14 s2 manual gearbox (perfect condition) (new syncros) (no crunching at all) comes with short shifter no clutch
some pictures can be found here
http://www.skylinesaustralia.com/forums/R3...95#entry5309695
ALL PRICES ARE NEGOTIABLE AND MUST SELL ASAP... MAKE ME OFFER... I WILL ADDING PARTS AS I FIND THEM
PICK UP PREFERED FROM KEYSBOROUGH/DANDENONG
0433087733
lowest price on coilovers ??
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
