  • Replies 91
I dunno, if you maxed out your 1600cc injectors, i reckon full boost would be like a throwing a bucket of water over yourself.
Correct me if im wrong, (probably!) but:
1600cc per min x 6 injectors = 9.6L of fuel per minute x 2mins = 19.2L of fuel every 2 minutes at maximum use of injectors?
  • 1 month later...
so we all know by now caltex will start sell E85 next month.
proposed caltex sites to start selling E85 next month.
WOODCROFT, Cnr Patalinga & Bains Rds
SALISBURY PARK, 1916 Main North Road
ST MARYS, 1129-1131 South Road
all we done with mine was take the fuel line off at the fuel filter and pump the fuel out using the fuel pump. then put a new fuel filter in the replaced the new fuel filter a few weeks later. i wouldnt worry about dropping the tank. just keep fresh filters in there so they dont block up.
Caltex E85 news
E85 is great for a track car. I am running +9 degrees over the BP98 map. I have run out of Injector though(1000cc)
Mind you cold start requires 70% more fuel...as ethanol doesn't like to go bang when cold.
Caltex E85 news
Run out of 1000cc injectors? Mat your crazy :whistling: 535kw!!!
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
