As exiting as it is for me to have someone on the forum who is awsum enough to apparently have a Ferrari, let me just say:
A) If you have such an issue with Nissans and Japanese cars in general, join a Ferrari Forum
B) Find me evidence of a Ferrari with a 5 star safety rating....
Interestingly, NCAP 2009 top five does have a Euro car on top
http://www.goauto.com.au/mellor/mellor.nsf...A2576BA000EDCD8
Followed by 2 Japanese cars (2+3), then a Korean (4), with another Japanese and 2 Euros coming in equal 5th.. so of the 7 cars in the top 5, 3 are Japanese, 3 are European, and one is korean, making it 4 Asian cars all up... NO Italians, 1 German....
Further to that, suggesting that saving weight reduces crumple zones and strength... Crumple Zones are a designed weak spot, which is in actual fact a direct opposite to strenght.
+1
Good luck to ANCAP getting a Ferrari for crash testing purposes in this country. Its funny when you read through the back of Top Gear AU magazine there is no crash test info on any of the supercar manufacturers, whether it be Lamborghini, Ferrari, Porsche or Aston Martin. I must say props to Audi though for letting the people at ANCAP destroy an R8, now thats commitment to safety.
In the quest for speed, sacrifices are made to weight reduction, most of the sacrifices reduce the strength and crumple zone of super cars. The Italians and Germans have done it right. By the looks of this car Toyota has forgotten about safety to build a stupidly quick car. In the end that is what you have to expect can happen when travelling high speeds in any car. A helmet can improve the chance of survival, but it doesn't mean you can survive big crashes...
grow up mate... no one wants to read that kind of elitist shit on here...
go find a ferrari fanboi forum where comments like that will earn you a reacharound from a rich fag while you all bukakki some hundred dollar bills
+11ty. what a homo.
what are you doing on a nissan forum anyway?
and this is your sig?
The car brand I support puts it's profits into motor Racing and stimulating their local economy to make more pasta, your car brand puts their profit into PR campaigns and the killing of whales...
shouldnt you be prancing around somewhere, trying to buy friends/respect?
Seriously? You are going to judge the absolute safety of the millions of cars made in Germany/Japan on one accident involving a single vehicle from each country? And also the safety of all Italian cars as well, how this is even the slightest bit relevent I'm not sure though.
The cabin of the LFA doesn't even look that bad, no visibly worse than the BMW cabin to me. I'd wager that the differing outcomes for the Lexus driver and the BMW drivers has more to do with bad luck, or maybe the fact that the lexus test driver was a frail 67 years old.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
