Hey all
Need to sell the following , Was building a four door r32 as a tough sreeter / drift toy but have just been informed my work is sending me to our overseas office for 6-8 months with the possibilty of staying over there longer.
ENGINE RB24 ( BOTTOM END )
BOTTOM END IS BRAND NEW
SPEEDLAB CUSTOM RB24 ( CUSTOM MACHINED R34 GTR CRANK )
GRUB SCREWED CRANK
EAGLE RODS
TOMEI PISTONS
ARP RACE SERIES STUDS
TOMEI RINGS
PISTONS HAVE BEEN TEFLON COATED
FRESH LINE BORE AND HONE
ACL RACE SERIES MAIN AND ROD BEARINGS
CUSTOM SUMP BAFFLES
CUSTOM 9L SUMP
N1 OIL PUMP
THIS BOTTOM END HAS BEEN MADE TO STAND BIG HP AND BIG RPM. ONLY TOP QUALITY PARTS FROM JAPAN, USED AND THE BEST MACHINING HAS BEEN DONE.
THIS BOTTOM END HAS COST ME CLOSE TO $10K
WILLING TO SELL FOR $7500.00
ENGINE ( HEAD )
FULL RACE PORTING
JUN 280 – 10.8mm LIFT ( BIG ) INLET AND EXHAUST CAMS
JJR ADJUSTABLE CAM GEARS
TOMEI SPRINGS
TOMEI GUIDES
GREDDY TIMING BELT
THIS HEAD IS TO SUIT ABOVE BOTTOM END, HAS BEEN FULL PORTED WITH BIG CAMS, LIFTERS, TOMEI SHIMS, TOMEI SPRINGS, GUIDES, WILL ALSO THROW A BRAND NEW GREDDY TIMING BELT IN.
THIS HEAD HAS HAD OVER $6K SPENT ON IT IN MACHINING AND PARTS FROM JAPAN.
WILLING TO SELL FOR $4,000.00
ENGINE ( PERFORMANCE / FUN STUFF )
GENUINE HKS 25/30 ( DONE 2000KM SINCE NEW ) $1400.00
XSPEED JAPAN STAINLESS LOWMOUNT EXHAUST MANIFOLD $ 500.00
HKS DUMP ( SERIES 2 WITH LARGER GATE OUTLET ) $ 350.00
MICROTEC LTX12'S WITH FULL WIRING $ 800.00
587cc SIEMANS INJECTORS BRAND NEW $ 600.00
TOP SECRET FUEL REG IN TOP SECRET GOLD $ 250.00
OS GIKEN TWIN PLATE, USED FOR 3000KM IN GREAT CONDITION $1000.00 SPEEDLAB DRAG COOLER ( 600 X 320 X 115 ) BIG! $ 700.00
R32 FOUR DOOR ROLLING SHELL WITH PLENTY OF PARTS, PRITTY MUCH EVERYTHING EXCEPT ENGINE, GEARBOX. CAR CAN BE REGISTED IN SA, HAVE REGO PAPERS FOR THIS
1990 SILVER R32 FOUR DOOR
INTERIOUR IS IN DECENT CONDITION FOR AGE
EXTERIOUR IS IN OK CONDITION FOR AGE
PARTS ON CAR AS FOLLOWS
CEFIRO CROSS MEMBER ( SITS THE ENGINE 30mm LOWER FOR BETTER GRAVITY )
KAAZ 2 WAY DIFF CENTRE
GTR DIFF CASING ( BETTER COOLING AND MORE OIL )
SOLID REAR FRAME BUSHES
SOILD DIFF MOUNT
CUSCO COMP COIL OVERS
CUSCO FRONT AND REAR STRUT BARS
CUSCO BRAKE MASTER STOPPER
CUSCO REAR UPPER ADJUSTABLE ARMS
ARC CASTER ARMS
EXTRA LOCK STEERING KNUCKLES AND ARMS ( FORGOT BRAND BUT THERE JAP )
R32 GTR CALIPERS AND DISCS ALL ROUND
TOP SECRET BRAKE PADS
D2 HYDROLIC HAND BRAKE AND CUSTOM LINES
BOSCH 044
CUSTOM SWIRL POT IN BOOT
N1 HEAD LIGHTS
MOMO STEERING WHEEL
HKS BOOST GAUGE
N1 BONNET LIP
EXHAUST MANUAL CONTROL VALVE
3 INCH EXHAUST
THERE IS OVER $10k IN AFTERMARKET PARTS ON THIS CAR NOT INCLUDING THE CAR ITSELF. THIS ROLLING SHELL IS A GREAT STREET / DRIFT STARTER WITH ALOT OF POTENTIAL.
WILLING TO SELL FOR $7000.00
Or
If someone whans everything as a complete package im willing to sell for $17K for everything !!!
OFFERS WILL BE LOOKED AT !
PICTURES WILL BE UP THIS WEEKEND.
I know your probably not considering this at the moments but if/when you are Id be interested in 2 way and the knuckles. Just send me a PM if it ever gets to that stage.
Any pictures or more info on the head? Who did the work, flow figures, std valves etc? Was the combustion chamber opened up to suit the larger bore of the RB24 or will it still work on a 20?
Hey all
ROY - Head work was done by SPEED LAB & RHEMAC ENGINEERING here in Adelaide, Its had alot of porting on both inlet / exhaust , it has tomei valves or JUN valves ( ill have to get back on that ), Yes the head will work fine on a RB20. As people know standard rb20 heads are very restrictive !
BL4CK32 - I will keep you in mind if i split those items
cheers
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
