I am looking at this car and was curious if anyone has seen it or know of it's history.
I'm not sure about the lip but below are the specs.
Cheers
2001 NISSAN SKYLINE GT-R V-SPEC 2
IN THE BEST COLOUR, BAYSIDE BLUE
39K KLMS, THIS WAS A PERSONAL IMPORT IN DEC 2009
THIS CAR HAS BEEN USED FOR PROMOTIONAL WORK AND HAS NOT BEEN DRIVEN IN THE LAST FEW MONTHS
FITTED WITH AS NEW ROTA (VOLK COPY) GTR 18" RIMS
KAKIMOTO RACING EXHAUST
APEXI DOWNPIPES AND CATALYST
BOOST INCREASE TO 1.1 BAR
APEXI FILTERS
NISMO STYLE CARBON BONNET
NISMO STYLE CARBON RAISED SPOILER SUPPORTS
AUTO SELECT STYLE CARBON FRONT SPLITTER AND CANARDS
ARC STYLE CARBON FRONT COOLING PANEL
HKS LTD EDITION SHIFT KNOB
NISMO LED TAIL LIGHTS
IMMOBILISER
FACTORY TINTS
HIGH VOLTAGE BATTERY (OPTIMA I THINK, COST OVER $400!)
INCLUDED IN THE SALE IS
*ORIGINAL TAIL LIGHTS*ORIGINAL SHIFT KNOB*ORIGINAL SPOILER MOUNTS*TEIN COILOVERS*
https://www.sau.com.au/forums/topic/326172-anyone-know-this-34-gtr-vspec2/
It's in UK. It is a business demo car made to look the same as a UK race car. Vins match for Vspec 2 and everything is straight
LOL!
It has the Nismo Z-Tune Bonnet (Not sure if it is genuine or not)
It's either Rays Engineering, Volk Racing Wheels or Nismo LMGT4 wheels.
LMGT4 wheels are not Volk wheels, they are just made by the same company = Ray Engineering.
Shit that high voltage battery is mad... *note Sarcasm*
The spoiler sits ridiculously high and the ride height needs more low.
The owner has the money for a R34 GTR but goes cheap and puts Rota wheels on and leaves the suspension stock...
Having said that, if the car and everything is straight and if you have seen the car in the flesh and all is good, then go for it.
Just change a few things when you buy the car.
BTW the car looks like it is in QLD... I can see QLD plates on the other cars.
i thought i saw this on carsales, how can it be in the UK?
v-spec II bonnet is FULL dry carbon, this would be fibreglass with CF overlay... maybe a JS Auto item?
Not sure why you'd change, unless getting a gen Nismo R-Tune
even though it says nismo 'style' i don't think they ever made raised rear spoiler uprights
it's weird that the seller has mentioned nismo 'style' for other items, yet fails to mention that the rear tailight LED's are also knock-offs and not genuine.
You can tell by the clear inserts, they're the ebay ones.
and does the stock diffuser match up with that front lip??
Its a personal import from UK and some standard stuff is still there.
I think the lip and diffuser are replaced with this CF lip.
Basically this car was prettied up to match a race car they had and used as a demo. (you know, like a standard car that goes to betta electrical with 888 all over it).
Cheers
APEXI FILTERS
IMMOBILISER
FACTORY TINTS
Looks like MJR at Burleigh
    • I'm at the point of seriously starting a project to build and Arduino/mc (of some sort) based multigauge to go in the console where triple gauges normally sit. I have found a screen of the right dimensions. I would need to 3D print a bezel/housing to make it mount up pretty. That's doable. I would need to come up with interfacing circuitry for the EGT thermocouple. I'm sure there will be examples of that into Arduino out there somewhere. Ditto with characterising the output of the existing boost gauge's MAP sensor and the oil T gauge's thermistor. And then, because it is a screen, it can be controllable, so it can show more than the 3 gauges I currently have. So I can come up with a list of other things I want to be able to show on it that can be reasonably easily handled via an Arduino's inputs. I do not need this project. But the stepper gauges I'm using are giving me grief. It's time to come kicking and screaming into the 21st century.
    • Would you really prefer pillar gauges over something like this? https://www.haltech.com/product/ht-067010-haltech-ic-7-digital-dash-kit/ Or if you can spend more, this? https://www.haltech.com/product/ht-068000-haltech-uc-10/ I could write a thesis about how much better a modern dash is compared to a series of gauges.
    • People think it's a waste of space, ugly, etc, generally associate "emissions control equipment" with "bad". These OBD1 vacuum-only systems I'm not a huge fan because I think they don't go far enough. They're wasting some of the fuel captured because they start purging as soon as the engine pulls vacuum. Later OBD1/OBD2 they put an electric purge valve on them to vent only when closed loop is active so the ECU will trim some fuel out. Even later OBD2 with zero evaporative loss the tank is 100% sealed from atmosphere until you run the engine or press the refuel door release. The tank has to take much higher vacuum/pressure spec but you never deal with saturating the charcoal canister and losing some fuel that way. The fuel also lasts as long as it would in a 100% airtight container which is nice when you're dealing with modern E10 pump gas.
    • If your luck is anything like mine, what happens is in the process of pulling hoses to get access to the one leak you create many more leaks because every o-ring was on the verge of failing and the strain of pulling it apart caused it to fail. Sometimes life is simple, sometimes you pay twice trying to save once. For the R33 you can still get most AC components from Nissan, I use nissan epc data or amayama to look up the part numbers and then search for the cheapest/most practical way of sourcing from there.
    • The dirty secret is there is nothing recyclable about the plastic bag or old plastic bottles either. Our local trash collection explicitly calls it out as hazmat in both cases. Oil-soaked rags + paper towels too. Oil-soaked cardboard is also not recyclable. The most common case of oil-soaked paper like that is pizza boxes, which are explicitly compost-only from the oil. To my knowledge hazmat oil contaminated plastic the only solution is either landfill or "thermal recycling". Most plastics in my experience there is slow permeation of the oil it's holding into the container so it's very challenging to get it 100% clean.
