Hi all, I just got myself an 03 V35 6 speed manual coupe. The car is fantastic but I just want to know what's the speed that you get up to in 1st gear at around 2500 rpm? The reason I'm asking is because I feel there is not much pull in 1st gear in normal driving i.e shifting at around 2000-2500 rpm and not redlining. It's like as soon as you got the car rolling in 1st then it's time to grab 2nd, else you won't go anywhere quicker than say 30kph. I'm thinking maybe this is just me.. but just thought I'd get some input from you boys.
Cheers
https://www.sau.com.au/forums/topic/326177-question-regarding-1st-gear/
@ 2000-2500rpm you're shifting to 2nd too early, that's the rpm you should be taking off at. Take it up to 4000 in first and change. You'll notice then when the pull kicks in.
Edited by mosoto
I just feel that the take off from stand still is quite slow. It's like you either rev until about 3500-4000 rpm before changing to 2nd or you change to 2nd early and accelerate from there. In other words, I feel that the 1st gear is having a very high gear ratio.
I timed a 0-100 sprint last night and I got about 6 seconds ish.. which is what the factory spec says so the car is working normally.
Sorry if I don't quite know how to explain this.
1st is for simply getting off the line, 2nd does the torque work. This morning I wound it up to 5000rpm and I was doing 40kph in 1st.
That sounds about right.
yeh just haven't got used to the v35 manual yet.
all 6 speeds have a short first gear.
I have an alfa 6 speed and its the same as my V35 6 speed
the shift is short but not too short.
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
