As above - currently using μTorrent, but lately hasn't been downloading as fast as it used to. I usually download PPV events - is the speed dictated only by the amount of seeds/peers, or is software a factor too?
https://www.sau.com.au/forums/topic/326186-torrent-software/
What sort of connection do you have?
In my experience the seeds and peers is obviously the biggest factor besides your connection. Also throttling back your upload speed will have a detrimental effect on your download speeds too. Here in Australia we are often limited by our upload speeds because torrents automatically give the better download speeds to those people uploading at a faster rate and those people are usually in North America or Europe. I think Utorrent is the best client, it uses the least amount of system resources and seems to give the same if not better speeds than other clients. Also Utorrent is the preffered torrent program for most of the private trackers I know of.
UTorrent IMO is the best for Windows based applications, it's light and fast. What you want simple software to be. However UTorrent has some very powerful config settings that can cause problems if you set up wrong :)
Seeds/Peers are a factor however there are also other factors to consider as follows.
UPnP
The UPnP setting (set the port to something over 50,000). Some ISP's will monitor ports below 40,000 and artificially shape your connections/requests originating.
I've found simply changing a port number to restore speed in some instances.
Global Connection Limits
Also there are some other settings that can be configured like the "number of global connections".
It is possible to MAX your router out with too many connections which will actually cause it to slow down.
I would assume (given you are asking such a question), that your router is not really high end so you want to set MAX Global connections to no more than 800-1000.
Active Torrents
Another thing to consider is the amount of active torrents you have.
There are limits within UTorrent, so have a look. If you have 100 active torrents (upload & download) then if you try for 101, it will give priority based on those which are active.
A torrent doesn't have to be seeding/downloading to be active either. If it's updating the trackers and so on i believe this to be counted as active so try bumping that number up by 50.
Or simply cleaning your current torrent listing (if you dont need them all active etc)
Checking Router Sync
Not sure if you know how to check what your Router is Sync'in @ with your ISP. But if you do - have a look and let us know.
Then also tell us your MAX download speed. You might find there is an issue with Sync speed and UTorrent is only running as fast as your connection currently allows.
Give the above a crack and report back :(
There are some other things you need to change, but for the life of me i can't remember so i'll check when i get home and update then.
lol - Just happens that cars & internets are my prime interests... Hence a forum with car stuff is gold :)
If you can check the router sync speeds - IMO that is probably the best place to start (even though its last on the list)
I dont understand how people can still use torrents, i used to use it, but only with private trackers like demonoid, supertorrents ect...
Direct downloading from rapidshare/megaupload is seriously the way to go, no wait, full speed, heaps of forums that act like catalogs to all the links, and really $10 a month (or $20 3 months, $100 lifetime) is worth it, in conjunction with IDM, downloading really doesn't get easier.( i also blow 250gb a month hording the internet)
lol at demonoid being a private tracker.
get on any half decent tracker and torrents are teh best.
OP: uTorrent for windows, there is no other option.
Lmao sorry man, I ended up hacking away at the settings being the noob I am - but it worked so I'm happy :P
:):laugh:
:laugh::laugh:
Damn you to hell boy! LOL!
PC Trouble shooting 101 - step by step.
That way you know for next time what to look for ;)
And i like to know for my own knowledge of what sometimes can go wrong (sometimes updates cause problems etc)
I'm a cheap ass Asian... that is a lot of unnecessary spending for me... :)
EDIT: also would like to point out that I used to torrent using a dial up connection (sync at 48kbps) so I'm very tolerant of waiting for it to finish.
Edited by Mayuri Krab
Yeah, that's what attracted me to it in the first place because I use my netbook for downloading/surfing whilst in bed lol
giggity!
usenet.
/thread
too hard to use, i just want to think of something i want, and 3 clicks later be downloading it
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
