Hi guys, i've been scratching my head trying to work out why my car isnt making power, and im fairly sure there is nothing wrong with my car, but its only making 230rwkw when the hyperfear turbo I have is supposed to make 270-280rwkw
heres a quick run down of what i have
1997 r33 gts-t unopened rb25det with 110,000kms - manual
* Hypergear 3076 equivelent in standard front housing and op6 rear housing (76mm 52 trim compressor wheel, gt30 turbine wheel in 84 trim)
* 550cc injectors
* 3" bellmouth dump/front
* 3" highflow catco cat
* 3.5" fujitsubo catback
* Z32 AFM
* Bosche 040 fuel pump
* Power FC
* highflow panel filter in standard airobx
running 20psi boost
OK well the Turbo is a Hypergear and is supposed to make 270-280 rwkw ... but Trent (from Status) could only safely get 230rwkw out of the setup
In the top end only 10 degrees of timing could be put in, before the car started to knock badly! Trent comented that usually he can get around 16 degrees timing, and that extra 6 degree of timing is most likely where the lost power is! but the car wont accept any more timing without becoming unstable
we tested the exhaust, by dropping it before the cat and it made bugger all extra power, so the exhaust is not a restriction
there are no restictions on the intake side, the intake pipe is not closing!
we removed the airbox lid and filter with minimal gains there also
and the turbo was glowing red/orange during runs with the fan going and even letting the turbo cool down sufficiently between runs
base timing is perfect
timing belt allignment has been checked and is also perfect!
im out of ideas as to why the setup is only making 230rwkw and why it pings at anything over 10 degrees timing in the top end!
anyone got anything i havent thought of?
https://www.sau.com.au/forums/topic/326193-what-could-be-causing-lack-of-power/
The fact the turbo is blowing as red as you say would suggest the cam timing/belt is certainly something that needs double checking.
The only time i ever saw my GT30 glow red hot was after extended periods of repetative dyno work or 20mins up in the hills.
Are the injectors new?
What is the fuel flow & voltage like? Did you rewire the pump (and not use stock wiring)?
Fuel filter been replaced recently?
Any interesting bumps/dips in the power curve at all?
What happens @ say 1bar? Same power or does it increase progresively until 20psi?
cam belt timing has been checked and checked again... definatly ok!
doesnt take much on the dyno to get it glowing!
injectors are brand spankers
fuel filter has been replaced quite recently
just used standard wiring on the fuel pump and have not checked voltage/flow ... although afr's seem fine, so i assume its getting plenty of fuel
The power comes on fairly hard.... but pictures say 1000 words... so i'll go grab the dyno sheet
I found this car's abit strange. Its running a .63 high flow, same profile has pulled 260rwkws on another RB25det, infact same turbo on a RB20 also made 260rwkws.
I also run a .63 rear with same profile pulled run after run nothing turned red like this one did just after 1 run.
The only way I can cool it down is using a .82 rear. which's been proven 260+rwkws on R33s. I will machine one for you comming week, If it doesn't work I really don't know whats the go with it.
I would remove everything and re-install the timing belt from scratch.
Ask Guilt-Toy about the issues he had with his car, it sounds very similar.
i did ask him, but he wanted money for his advice
how obvious is a tooth out on the timing belt in terms of behaviour of the cars running performance, it idles fine, revs fine, and still feels fast! doesnt spit or splutter!
i did the 100k service myself.. changed; timing belt, idler and tensioner pulleys, front crank seal, water pump, thermostat, top and bottom radiator hoses, rocker cover gaskets, half moon seals, spark plugs, oil, oil filter, fuel filter, air filter, a/c belt, p/s belt, alt belt, radiator cap etc etc
and the only thing i can think of that could be affecting all this is the timing belt, but i was confident when i put it on,
And to double check, just the other day i pulled off the top timing case and pulled out #1 spark plug using the long screw driver trick to find TDC on #1 and then looked to see if the marks lined up, which they did!
so i got no idea
:miner:
i didnt check the bottom line, but assmed it wold be right as i was quite confident when i installed the timing belt, bt also because when i checked it the other day i found tdc on nmber 1 cylinder and the two upper marks matched,
sounds like its right but worth checking anyway, the old screwdriver on the cylinder isnt always spot on, as theres few degrees where the piston doesnt really move. take 5 mins to pull off the top cover and turn it to TDC. not doubting you at all, just better to be certain than confident
Turbo will always glow red after some dyno time dont worry.
No harm in triple checking timing on the cam belt, was the keyway on the crankshaft ok? if its slightly moved and damaged the cutout in the crank it can give u false timing readings when checked with a timing light.
When u check the mark on the crank pulley to the timing cover, the timing may show 15btdc but in fact it may be totally different!
If possible maybe try changing CAS, as although it may seem fine, it might be getting noise interference or similar, or may just be on the way out.
As a result iginition timing may be jumping around everywhere up the top, causing the pinging at conservative timing.
Good luck mate! :)
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
