Hi all,
Just want to know what people suggest doing when starting my engine for the first time after re-installing the engine.
The engine was fully built, run in and tuned on the dyno, and did roughly 1000ks of road driving before breaking a valve guide for no apparent reason and bending the inlet valve on no 4 cylinder.
Anyway..... I then removed the engine from the car unbolted the head and sent the head back to the builder who replaced the guide and the bent valve for me under warranty.
The builder sent the head back to me all set up with cams fitted and the head has now been torqued back down, and the motor is finally now back in the car ready to go.
Im nearly at the stage of starting it again, should i just unplug the coil pack harness and unplug injector harness and crank the motor to regain oil pressure? And obviously bleed the coolant system? Anything else?
Do people think it will be right to just start driving it again normaly.... taking it easy obviously, seeings that the tune hasnt changed?
Or should I at least plug the vipec into a laptop and look at knock? Or do i really need to get it back on a dyno and check air fuel ratios?
Sorry for all the questions just dont want to go through the pain of stuffing it again.
Any help is much appreciated.
Just unlpug the CAS and give it a 10-15 sec crank.
That should do it - make sure you have a good battery :down:
If you've really not changed much else (sounds like cams are the only thing, and thats nothing too major)...
Should be fine just to drive very easy until you get to a dyno just to check everything is in order.
I would certianly check it either way - silly not to for a few power runs after reinstalling the motor. EG could have a split boost hose or something silly you've not picked up. Good to have it in controlled conditions, watching it all closely for a couple runs and so on.
Thanks for that mate.
As long as startup goes ok and everything seems right i will just take it for a short drive round the block then keeping it under 3 grand or so and check for oil leaks and so on. Then back on the dyno just for peice of mind.
Can anyone tell me if there is any sort of error or knock log on the vipec that I can have a look at when i get it going?
Just to see if it says anything from around the time it bent the valve?
I was there for the tuning of the car and watched them do it but Im not real familiar with the software.
And how do i go about lowering the rev limit once i plug it into my laptop? Wouldnt mind dropping it back from 8600 to around 7500ish just for peice of mind as i REALLY dont want to go through this again.
I'd turn the engine over by hand just to check you dont have any valve to piston touchy touchy...
Once you have checked and re-checked the cam timing, pull the plugs and turn it over by hand untill you get oil pressure, re-install the plugs and start her up.
Then chuck a timing light on it to set base timing.
Go for a drive and monitor the afr's and knock levels... Personally I'd throw it on the dyno just to check it out.
J.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
