Hi Fellas,
I've decided to get wide body rear guards to be able to get thicker wheels on the rear.
I have an R33 GTS-T with 380 rwkw (alot of traction issues), hence, why I am intending to put 10 inch rims on the car with some 275 rubber.
Now, I have two decisions as I see it. The rims I want for the rear come in either 18 x 10 +22 offset, or 18 x 10 -1 offset.
Would the 18 x 10 -1 offset look too extreme? Would such wheels fit on a standard GTR on the rear?
How much would the standard rear guards need to be pumped out on a GTS-T to accomodate for these wheels and tyres?
Bear in mind I would like the tyre under the guard and I am intending to put 275/35 18 tyres on the rear.
Any advice, opinions and suggestions are appreciated.
Cheers
https://www.sau.com.au/forums/topic/326239-rims-to-fit-wide-body/
Your +22s would easily fit in gtr guards will no mods, in fact might even be too high and offset for a 10" rim. The -1s would look sweet as put you would probably need some serious guard work to get under gtst guards. Do it through.
18x10-1 with 275's will not fit under stock metal without a LOT of flare unless you wanna run your car like a 4wd
as I recall you don't have a diff do you? The money would be better spent on a 1.5 way diff so that you are actually putting down all that power... On a stock diff that hasn't been recently reshimmed you will be trying to put down 380 rwkw through 1 wheel and that's never ever gonna happen
what's the rest of your suspension like? What Tyres do you run?
For example, with my setup federal 595s start to fail in 2nd gear WOT at around 270rwkw
when I run any more power they will simply not hook up, however my nitto NT05'a will hold all of second with 325rwkw and could take a lil more if I had it
u dont need wide body to fit 18X10-1's bro
lil lip and roll and thy will fit fine.
dont waste ur money on wide body or gtr guards unless ur going way wider thn that with way more dish.
regards
julz
Serious? I got 18 x9 + 37 on my rear now with 265 tyres and I got about 1 cm gap to the guard. And that's with slot of negative camber ...
the general concensus of buying rims in my circle of friends (we all have silvias, 180s, skylines and chasers) is to go out and buy the most extreme rim u can afford and make the c@nt fit bro.
my car is about to get its second paint job to accomodate the rims im buying very shortly (hopefully tonight when the dude who bought my brides pays me :miner:)
....am i the only one who notices here that OP was asking whther or not to sell his car and after 8 or so pages of lengthy discussion he decided to sell his R33 and get a WRX after taking one for a test drive??
op - you don't need wheels to fit wide body. you need to find God. haha
furthermore...
your proposed wheel fitment probably won't require widebody. look up www.rimtuck.com for ideas of sizes and fitment.
to clarify - OP - i really hate you because you keep asking questions and i keep helping you out.
your proposed fitment is posted in this link ... 18x10 +22. keep in mind that's an R32 with smaller guards than your 33... so the proposed fitment will fit fine
again in this link
you'll find R33 GTST with 18 x 10 +22 running a 245/40 tyre. he's not running widebody or lippage.
another pic here to see the real fitment. keep in mind he's running an 18 x10 +22 on FRONT also.
no widebody. no guards lipped
so not only will you now see that not only do you not need to lip, or to widebody... you will also see your wheel choice is infact quite conservative..
one more thing. i don't REALLY hate you. but it's quite annoying that i can't help but get baited into writing essay posts only to see that my heart felt advice is just water off a ducks back to you haha :miner:
edit - see? as i said. i can't help but get baited into helping you out. lol
okay you want a 10 inch rim onto a 275 tyre...
275 = two hundred and seventy five millimetres wide...
onto a 10 inch rim. - i'm assuming you already know this... and i needn't explain it to you
but
275mm = 11 inches. the tyre will be too wide for the rim of the wheel. and if you put this 11inch wide tyre onto a 10 inch rim.. then put the setup on your car. ninjas will come out and kill you, and kill your family, and kill everyone you like...
that's a fate worse than death my friend...
no seriously it won't cause any issues... but it will look a bit retarded, esp in a 35 profile, and thinking about it - it probably would cause your guards to rub
my advice... change guards and widebodies to fit a WHEEL fair enough... but for a consumable like tyres? nah. that is wack...
you should get the same amount of grip /traction running say a 255 or 265 provided you get a higher end tyre... rather than getting a 275 just for the sake of having a 275
Edited by Mr Eps
NERRRRRR i already TOLD him that!!! DUH!!!
SEEEEE????
Lets start taking wagers on what the next thread he puts up will be about because I am having a hard time following his descisions. So we obviously aint selling the car any more?
Yes, my car puts me through many hard descisions, which results in many conflicting posts. The reason why I've decided to keep it is because I realised ill never get close to getting even half of what I paid for it. So I may as well keep it and enjoy it :P.
so what's the sussy setup?
I have beilstien shocks all round. K-mac lowered springs (progressive, so they aren't too hard, but not too soft, feel real nice)
Tyres I am using currently on a 18 x 9 +37 wheel is a Khumo KU36 (I think). Tyre is 265/35 18.
The other reason why I am having traction issues is because I got a SH!T load of negative camber.
When I touch the rear tyres after driving, the inside is hot, the outside is cold.
I've purchased a camber kit to add up to 0.75 degrees positive camber, but I cannot fit it because the tyres are already so close to the guard, there is no room for positive cambre adjustment.
Hence my reason for thinking, make my wide body with 275 semi slick tyres (Somewhere around the $700 pair range like faken RT615s) on a 10 inch rim, I can get two camber kits and have adjustment up to 1.5 degrees on either side.
I do have another option as you said above, getting a 1.5 diff.
But then again, I'd have to get smaller tyres (probably 245s) get my camber kit installed, get the diff installed, and hope for the best my 380kw still don't spin the rears......
Not to familiar with diff work, but off the top of your head, how much would it be to get a 1.5 diff supplied ad fitted?
Thanks for your help.
furthermore...
again in this link
one more thing. i don't REALLY hate you. but it's quite annoying that i can't help but get baited into writing essay posts only to see that my heart felt advice is just water off a ducks back to you haha :P
but
EPS, my man!
Not sure if you've noticed, but I am having TRACTION ISSUES (in addition with some personal issues), hence why I wanted to get a wide body, with wider rims, wider tyres and more positive camber.
Puting links up on my post of cars with 10" rims and 245 tyres that look like 4wds isn't going to solve my traction issues.
Yes, the r32 in the first link looks nice with the rims, but the 235 stretched tyres on a 10 inch rim, are they really going to help me with my traction issues? Probably not....
As I wrote before, I have 18x9 +37 rims on the rear now, with 265 Khumo KU36 tyres, and it spins all over the place because of alot of negative cambre (and probably not the best suspension work.
However, I don't have room for more positive cambre, why you ask? because the tyre is so close to the guard already. so Imagine a 10 in rim, with -1 offset, it'll bring the wheel out a further 5.1cm.
So Mr EPS, What do you suggest, I suggest you quit hating, and start participating.
And your advice isn't water off a ducks back, I enjoy reading your input. :D
are your guards lipped?
if not then there's an easy fix... if they have been, then pump them a lil more.
i'm running 18x9.5+25 all round and have the rear guards pumped enough without "flaring" to accomodate 245's and near flat camber on WOT
as seen here
you are currently running kuhmo ku36's, so tyre choice is decent :P for now get them swapped onto the opposite rims to wear down the opposing sides
a 1.5 way diff will set you back around 2k. look at the nismo gt lsd pro diffs, as they are the quietest, especially the TT model (hell i drove my 83 year old grandmother around the other day with it)
when i pin the car it hooks up 100% of the time and has been possibly the best mod i have ever done. the car is a different animal to drive and is a million times more fun as it is totally predictable.
with a 1.5 way you dont get compression lock ~> death in the twisties either.
personally i would run a welded diff before i run a stocker, but this is not for everyone... however i run one in my ksev, and i love it... and i hae no idea how you'd go with 380rwkw and a weldy... the most i've driven with one is 260rwkw
you could also look into adding more shims to your current diff to test the waters if you are confident with DIYing it (kinda pointless to pay somone for labour, as you will love it and buy a diff soon anyway)
swaybars are also worth a mention... @ 3-400 they are definitely the best bank for buck mod you can do
my advice is to keep your current rims, get a diff of some sort, get swaybars, install your camber kits and see how you go.
i guarantee you will start to love driving your car again and it will make all the other money you have spent feel like it was worth it
you could also go to a meet and have rides in people's cars with diff's to see the difference ;)
