Wheels, Dc2 Oem Lip, Jdm Magnets, Audio,
Hi! My R32 GT-R has developed a 4wd light I've done some error finding and need to have some input If i start the car i get the 4wd lamp in the cluster and errorcode 18 (18 – ETS pressure switch or circuit) I've tested the pressure switch and it's normally closed to earth when car is off and if I run the pump manually via the relay in the boot the switch goes to open so the switch seems to work. The pump does not sound bad and builds pressure within a 1-2sec from cold and makes the switch go to open state If i run the pump for more than 1-2sec it changes sound from a normal pump sound to something that sounds like a hising/overflow sound so that seems ok I can actually get the 4wd to work if i manually run the pump for 1-2sec , then set the ignition to on and starts the car Can it be a bad nitrogen canister? I've checked all power and earth to the box and solenoid/motor system and it's all fine
By funkymonkey · Posted
https://www.v8sleuth.com.au/controversial-bathurst-winning-nissan-godzilla-to-re-emerge/ -
Yeah I'd say you've got more in common with the V35 lads as the Elgrand rocks the VQ35DE. Is yours the Autech version? -
So these creme caramel puddings are one of my all time favourite things ever. Was one of the first things my grandma taught me to make and I've made them ever since. Didn't know it was a thing in japan! I've always ordered a creme brulee (which is literally this inverted and blowtorched with sugar) at shops but never found caramel puddings mainstream in oz. Pairing it with a coffee... f**kin genius! -
Welcome! I'm heading over to SF/Dublin next week, and then gonna drive over to Reno the following week. Last time I was around there I spotted one stanced 240SX coupe with a silvia frontend swap in 3 weeks... was starting to wonder where the imports were!
