Clutch has shit itself.
I need a new/decent second hand one asap. I use my car for work so have to get it going tomorrow (saturday).
Can anyone point me in the direction of someone with clutch? I've had no luck looking here or on the WWW thus far.
It will need to be cheap, unless who ever is selling is happy to get some money today and the rest next week (ie 300, maybe 400 today, the rest on Monday).
Please help!
Either post here, pm me or call/sms on 0418 994 629
Cheers,
Aaron.
https://www.sau.com.au/forums/topic/326271-urgent-help-needed/
I bought my last from these guys off ebay:
http://cgi.ebay.com.au/EXEDY-HEAVY-DUTY-CL...=item4aa2619154
and when I contacted them direct:
gave me discount and free hat over the ebay cost...
http://northernbrakeandclutch.com.au/ for contact details
so that should suit your under $400 this weekend...
alternatively you could use:
http://cgi.ebay.com.au/Nissan-Skyline-RPM-...=item3ca4beb6d9
but I have never dealt with these guys and no idea on quality of that brand..
Thanks guys.
I got one from Bundoora.
It's only a standard clutch, and I would have preferred a heavy duty one, but I couldn't to Northern Brake and Clutch in Sunshine unfortunately.
Just had to drive the car from Skye to Bundoora then Bundoora to Hurstbridge with no clutch.
I'm knackered.
They're a decent brand CI...we use them at work all the time never heard a bad thing after selling one. Catalogue and range is fantastic.
shame i have an extreme clutch some sprung button extra heavy duty 6 paddle thing....fs with thrust bearing as well. Would have delivered too as headed out that way.
Doh!
Did the change today.
Old clutch was an RPM HD clutch. It was totally rooted. Like I think the most rooted clutch I've seen come out of a car.
Did a GB oil change too. Wow. Metallic paste spewed out when I pulled out the plug, along with bits of a syncho which I's say is from my 4th gear.
I must say, R33s are very, very easy to do clutches on. The whole thing done in about 2.5 leisurely hours. Of course having a hoist and well equipped workshop helped.
    • My car is also flex tuned. It's worth mentioning it (the LS1 ECU) has a 1D table for E85 addition and just uses the ethanol stoich part as the second point of reference. It also as a 3D timing map for Ethanol adjustment. You would think this isn't enough but it works pretty damn well. That said, I wouldn't want it in turbo application. It's like lifting non-natty, or taking meth. It gets you unrealistic results that break down more things going forward. If people used it to make the same amount of power they do on 98 then it'd be one thing. But people use it, crank it up to eleventy million PSI, it doesn't knock - but it pushes the point of failure to another, more expensive thing to break. Every time I see someone make 280kw on 98 and 350kw on E85 on the same equipment I just cry a bit and really wish they would just stay on 98 in that exact scenario. It's bad for you.
    • This is kind of what I was thinking but the temp sender wire and the two pressure switch wires run through the starter subharnes and I eliminated the two pressure switch wires completely.  @GTSBoy I have a can gauge with unusually bright warnings should the oil pressure fall so the factory light isn't needed. I need to dig out my wiring diagram and see if I can sort this out.
    • It's a valid point. And it is doable with the Nistune. But I'm not inclined to flex it the way Nistune does - certainly not on a Neo ECU. They're already pernickety enough to tune just one one fuel. And of course, I'm not that interested in putting in a Link or similar, on a daily. With the stock ECU, stock looking turbo, etc etc, I still stand a chance of surviving a run-in with the plod. Last time it went over the pits (which was for the transplant, for because of a run-in with the plod), the Nistuned ECU did not even raise an eyebrow. They want to see a stock ECU running the engine, and they are happy to see it do so without the check engine light** on. Never mind that the Nistune is necessary to make the stock ECU work in a different chassis without ABS, TCS, etc. **And they actually provoke the CEL to come on by disconnecting the AFM, to prove that the globe hasn't been pulled!
    • This is why you flex fuel it...
    • That is what I took from it too. Needed to go AWD S14 imo.
