i ended up going where we went this morning but couldn't see u guys, oh well, i don't have a mobile either, as for another cruise i'm not sure yet depends when everyone else is available, a cruise up in launnie would be cool but i don't know my way around up there.
I wasn't driving as quick as u guys as i don't like to thrash my car and i prefer to stick to the speed limit, hiring a race track for the day would be cool to really test our cars speeds but i think that would be a little expensive
https://www.sau.com.au/forums/topic/3263-cruise/page/2/#findComment-58312
Guest Anthony_males
Hi, I don't own a skyline atm, but soon. Anyway I drive a Subaru Liberty. For you guys in hobart you may be intreasted in groups.yahoo.com/group/h-j-p We are orginising a track day at Basky this weekend. It's $50 for HSCC (Cams lisence Ect) membership and $50 per day on the track. Either email me [email protected] or join up to H-J-P to find out details. Even if you don't want to go on the track come up and meet up with us. :)
https://www.sau.com.au/forums/topic/3263-cruise/page/2/#findComment-58780
Hey people... Thought I would like to add a comment about the cruise..
Was a great ride... Roads were awesome and the scenery was nice to look at.. Really look forward to the next one.. Might even have the Drift project car up and running.. Never know could look for some rally style roads and have a bit of fun..
Later
Steve
https://www.sau.com.au/forums/topic/3263-cruise/page/2/#findComment-58819
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
