Hey guys have a look at the RB26 we are putting into a clients R32 GTSt.
Mods are pretty basic.
We found a nice low km R33 GTR RB26 as a good donor. We then pulled the turbos off and put our rebuild kit sourced from Garret to 360 deg bearings and a high flow steel wheel rear exhaust wheel.
We pulled the sump off to modify it to be rwd. New water pump timing belt nismo thermostat and cam gears.
New set of nismo engine mounts and we dropped it in.
Will be controlled by a power fc running 18psi and our own power fc boost kit
Take a look at the pics.
https://www.sau.com.au/forums/topic/326333-rb26-into-a-r32-gtst/
Yeah will wheel spin everywhere.
Money run out for the gearbox right now so the 20 box is back in I will just tune it for 18 psi as the box will be fine on the dyno then turn it down to about 12 until the box goes in.
Power fc as it's what was in it running the 20. We put a modified gtr power fc on it a few years back so I just reversed the mod to run the 26 again
The way he drives it will last a while at 12 psi should make around 230 and hold on till the 25 box goes in.
The sump baffle is money well spent we should have put an N1 oil pump on it but the 33 gtr pump will do the job it doesn't need to rev past 7 will be hard enough to drive as it is for the owner
Nothing wrong with the R33 pumps! Mine is still/was going 5 years ago and when I recently sold the car.
Revs seen as high as 9500 when I first got it (stock engine with N1's) then when I forged it set rev limit to 9k, but usually never saw more than 8-8.5k
Just avoid limiter banging and it'll live a long life!
I killed my RB20 box in less than a month with 270rwkw... hehe.
It was in excellent condition before that :D
Should have given the rockers/plenum a lick of paint before putting it in, much easier to remove/fit out of the car :P
I did the r26 gtst conversion myself in the carport about 7 years ago. Easy. Everything just bolts/plugs in together and chop the diff off the sump. Don't even need to weld it. My g/box with about 220rwkw lasted and survived a few drift and track days plus lots of thing I can't mention here. Loved 2nd gear launchs. Always put a smile on my face expecially since the 26 motor cost me 2k inc loom/afms etc off a wrecker in NSW back then.
Best bang for buck thing you can do to a 32 gtst.
Yeah with the right crank the factory pumps are better nut still live a short life if you give the engine a real hard time so I carnt see thus one letting go anytime soon.
I bet at tha power ash you would have been hearing clunk clunk clunk pretty soon. It's the shifting hard at that power that does the most damage.
Yeah I suggested painting them and je said one day think he is after the orginal worn look until he knows the cops lift the bonnet then shut it. Will be running the airbox so will be pretty stock bay.
Shh it's not that simple lol. Was a bit more stuffing round changing the 33 gtr loom back to 32 gtr and a few hours spent cutting the shit out of the sump then cleaning it all up. But it all just slots in.
It's funny to see just the slight changes from the 20 to 26 just as simple as the inlet for the power steering pump is at a different angle just the little things we have come across just pain in the arse things that you have to find the parts or head down the wrecker.
Shit 2k back then couldn't complain about that for bang for buck would have spent more then that trying to even get a 20 anywhere close to that.
Your spot on mate that is his car. I had the engine sitting in the shop for about 8 months waiting for him to stop the car off.
For sure keep popping your head in to see where it's up to. Just time to fit it in with everything else we got in in the shop.
Bugger i got a few R32 gtr looms laying about i would have swapped for the 33 one to make it plug in for you.
If i get lined up by this thing i think i might give it a wide berth i get the feeling it'll be a bit of an animal. :cool:
I'd love to do a conversion like this on my 33. A mate of mine really wants an s15 with an rb26 his dream ride i guess.
Haha mate yes this thing will be a big quiet achiever. The thing looks bog stock with the 32 gtr rims and doesn't look modified at all. Same as the engine bay we are keeping it low key stock air box with a few ducting mods and running mostly everything stock gtr and getting the most out of them.
It should be hauling around 300 with 18psi. I am using a bade tune from a 32 gtr I did with 34 gtr n1's very similar spec to these turbo's and made 315@19psi stock injectors and afm's but they were maxed out.
I'd like to run this against my gtr when it's done but I think 4 wheels are better then two.
For sure mate book yours in if you want i can get your car hauling.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
