Did the same conversion in mine but mines a r33 4 door but the rb26 was worked, forged pistons, acl bottom end bearings the works. I love it, i rekon its the best thing ive eva did to the car,i put a 34gtt gearbox in, lots of wheel spin and fun. :thumbsup:
For sure the rb26 is a great engine conversion for any Nissan I've seen them go in 260z's would have been nice if Nissan had made them 2.8 or 3l from the factory but they are still a great engine at 2.6
HKS V-Cam!
:thumbsup:
Got the car up and runing last night fixed the few issues it had and test drove it. Test drove very good even at 8-9 psi moves nice. Will get it on the dyno and tune it up
Nice, post up dyno chart when done.
Finally got the car onto the dyno only had enough time to get some prelim tuning done up to 10psi as the client wanted the car back so didnt get enough time to install the boost controller.
Here is a video of the car on the dyno, as i said earlier that we used the RB20 gearbox and as you can here in the video the 4th gear syncro is worn and has seen better days.
Enjoy some RB sounds on the dyno.
  • 3 weeks later...
The new E1280s from adaptronic is pretty sweet isnt it? even the old boxy version was pretty sweet for basic applications. The new one will probably replace the d-jetro PFC in our race car soon for a bit more R&D
Hey Trent
It's a nice bit of gear for the price far more advanced then a dejetro for a track car you have all the nice little features plus the ve tuning i started out with the e420c without ve then upgraded the firmware to ve and was much nicer.
Have you played with and mega squirts?? A mate of mine in qld swears by them the new ms3 has got some good features for a dirt cheap ecu the only downside you have to stick them together but a few place in the states put them together as a built unit.
Been playing around with your favourite ecu tonight pnp wolf v4 on a 33.
To be honest I Carnt go past nistune for any Nissan I really love to use them.
Ahh fair enough good excuse. Would like to get to the states one day check out the cars we are heaing to japan in October after Bathurst tho.
We are going to try do a full Vic season next yeah in the 31
  • Like 1
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
