Got a mates s13 which has a stock rb26dett and ECU. It idles fine and free revs fine. When driving flat foot it seems fine but is slow. When driving at constant speed and boost is around 0-5psi it starts to surge bad. Like when you back off the throttle with no BOV how the air rushes back into the turbos but it happens continuously while on the throttle. Cam timing is correct but for 20 degrees ignition timing the CAS seems to advanced. It back fires a poop load.
Any thoughts. Its a real pain in the arse to drive.
Dave.
https://www.sau.com.au/forums/topic/326343-s13-stock-rb26dett/
Well i pulled both turbos off today. Front is fine but the rear has lost its wheel completely. Did a compression test before i drove it home with a blown turbo and all come up at 160 -170 but #6 was 112 :D Will do another one later in the week.
Car ran like absolute shit, haha. My guess is O2 sensor sensors are buggery too. Had been running rich for a while before the turbo went. Mate has no cat in it either :/
So im thinking my mate should. Get a set of decent 2nd hand n1 turbos, new o2 sensors, new plugs and a cat.
You think it should be fine with having only #6 cylinder that low on compression??
Does the ECU need the sensor that taps in the exhaust around the middle of the car?
Edited by Ganador
Well i pulled both turbos off today. Front is fine but the rear has lost its wheel completely. Did a compression test before i drove it home with a blown turbo and all come up at 160 -170 but #6 was 112 ;) Will do another one later in the week.
Car ran like absolute shit, haha. My guess is O2 sensor sensors are buggery too. Had been running rich for a while before the turbo went. Mate has no cat in it either :)
by the time you find and buy the used n1 turbos you might as well have just saved time and ordered some new garret bolt in replacements.
Ouch that's not good. Probably just needs hone and rings but if you go through that much effort, for $2500 can buy forged rods pistons head gasket and bearings from spool.. Good for a long time then.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
