White 1998 R34 Gtt Coupe
Item Summary: R34 GTT White 235rwkw
Condition: Used
Reason for Selling: No longer needed
Asking Price: 17000
Delivery Methods: PickUp
Contact Info: PM
Extra Information:
Hi I'm selling my white 1998 r34 gtt coupe that has done 135k km. I have owned it for a year and have had no issues with it. It is currently tuned for 235rwkw but it has the modifications to support 280~rwkw with a retune.
Modifications
HKS 3037 Pro S turbo kit
HKS Type S oil cooler kit
Greddy FMIC
Apexi Powerfc
Bosch 040 fuel pump
Deatschwerks 440cc injectors
turbo back 3-3.5" exhaust system
Pod filter
Tein adjustable suspension (think it's either HA or HR)
DBA 4000 series slotted rotors
19" advanti racing rims
Alpine Mp3 head unit
JL audio front splits running off a kicker 200.2 amp
Kicker 12" sub running off a kicker 750.1 amp
Should hopefully have some pictures up this weekend.
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
 Share
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
