White 1998 R34 Gtt Coupe
Shiminto
 Share
Item Summary: R34 GTT White 235rwkw
Condition: Used
Reason for Selling: No longer needed
Asking Price: 17000
Delivery Methods: PickUp
Contact Info: PM
Extra Information:
Hi I'm selling my white 1998 r34 gtt coupe that has done 135k km. I have owned it for a year and have had no issues with it. It is currently tuned for 235rwkw but it has the modifications to support 280~rwkw with a retune.
Modifications
HKS 3037 Pro S turbo kit
HKS Type S oil cooler kit
Greddy FMIC
Apexi Powerfc
Bosch 040 fuel pump
Deatschwerks 440cc injectors
turbo back 3-3.5" exhaust system
Pod filter
Tein adjustable suspension (think it's either HA or HR)
DBA 4000 series slotted rotors
19" advanti racing rims
Alpine Mp3 head unit
JL audio front splits running off a kicker 200.2 amp
Kicker 12" sub running off a kicker 750.1 amp
Should hopefully have some pictures up this weekend.
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
 Share
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
    • Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
