My friends car missfires on cold starts when warming up, but once warm it only does it every now and then, also when turning left and putting foot down a little bit it will sometimes missfire as well. Engine is a RB25DE.
When cold start in cold mornings say foot is down 5% it wont do it but when at 25-75% it will just stutter, also idle at lights when stopped makes his car sound like it has lumpy cams and vibrates a bit? oh and the car is just generally slow when under these effects.
Any ideas? I thought it could just be spark plugs but not sure. (could be condensation in mornings or something?)
Thanks in advanced.
Checked coilpacks? Do a search on missfire and more often than not coilpacks are the problem. Before i put my splitfires in i had the same problem, idled rough as f@#k - sounded like a rotary. Coilpacks fixed this issue for me.
check the spark plugs as well, my 25det was miss-firing a bit, i changed the plugs and re-gapped them to .8 and it was all good, only cost me $12. also, if you have a series 2, check the coil packs, they are prone to forming hairline cracks which the spark jumps from. if they are bung, try repairing them before buying new ones, theres some good threads on how to repair them on here.
Agreed to coilpacks as a suspect.
Mine did very much the same thing, but since I put splitfires in it's been perfect. 1.1mm gapping on iridiums for the last 3 years and it doesn't miss a beat.
Possibly even the knockoff red and yellow "jacket" coilpacks would be fine too?
I have the exact same problem with misfires on cold start. Car idles a bit rough also when it's cold but on warmer mornings this does not happen.
I have new splitfire coilpacks and new platinum plugs and also second hand r34 gtr AFMs, this has reduced the misfires but I can still feel it. Like others once the car warms up it's fine.
Might be a plug gap problem? If so then should I get some copper NGKs and get them gapped to 0.8mm?
yeah id start with the plug gap, its easy to do yourself, and will take under an hour. then work from there :blush:
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
