Hey forum just a quick question about my power steering. I have a r33 series 1.5 with air bag in the steering wheel, yesterday I replaced the steering wheel with an aftermarket one and the steering is now really stiff. I just replaced with the standard boss kit leaving all wires disconnected. The steering really is horrible without the power steering and I wanted to know if anyone knows what I did wrong and has a solution to get the power steering back. I had my hicas removed and replaced with a delete bar a little while back , so the hicas light is on but it does not affect my power steering as it was driving fine until I replaced steering wheel yesterday.
Edited by Daboss
https://www.sau.com.au/forums/topic/326457-power-steering-problem/
Did you use a HICAS-specific boss kit? If not, your steering sensor won't be getting engaged and HICAS might be throwing more faults. From what I recall, HICAS has a connection into the power-steering solenoid.
Quickest check would be to put the original steering wheel back on and see if that fixes it.
Anyway, hopefully others will have more ideas :)
(Searching HICAS-specific threads for information might give more clues too)
No didnt use a hicas specific boss kit, just a regular one. Took the wheel off and all connections didnt plug anything back up and replaced it.
i dont know of a way to bypass it. if there is a way, i'd love to hear it.
i left mine unplugged, just to see if i could get away with removing it. 30 seconds into the drive, the steering would go heavy. did it several times, then connected it back up.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
