  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
  • 1 month later...
Update
Engine just had a refresh and a check up, reason being the balancer sheered the key in the crank and damaged the crank collar. Brand new r33 Gtr crank( balanced) with new bearings put in to replace the old ones
it now has a ati balancer on it also.
Inner and outer tie rod ends and upper camber arm bushes were also replaced while the engine was out.
12 months rego just put on
Price is $32000 firm
I purchased the car from Autostyle, this is the second motor, the first engine I was told it was a Jun built engine when I bought it, but I found out it was a standard engine with head work and bolt ons when it popped.
  • 3 weeks later...
  • 3 months later...
  • 5 months later...
  • 1 month later...
  • 2 months later...
Just an update:
Car is getting new front and rear window seals put in and some body touch ups, price is $27000 firm
12 months rego also put on, and also getting a full service done once the seal are in.
  • 2 months later...
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
