You could ask Streeter or Import Monster to get a rail for you
If it's any help the Bride FG rail in my S14 has a width of ~430mm between mounting points (you can adjust the width, maximum 430mm)
That's plenty big enough for most regular sized seats. The FG rail is available for R34 too, in terms of an 'off the shelf' rail I think it's the best option.
You could look at a Chinese rail like 'powerrail' too but i question the quality.
Not sure what bride rails are like on other cars but the ones I've had are absolute Shit. Paid a fortune for them. Would be better to spend that money on generic rails and get a fabricator to make it mount to your car.
(Depends how much you can get them for)
What problems did you have with them?
Mine seem spot on, really well made and bolt right in, plus they slide too which isn't a bad option to have.
Mine were AU $300 delivered. Made to order by Bride too which is cool.
  • Like 1
The bride's for pulsar is single piece, can be very tough to move and not smooth at all.
Brand new around $350 a seat, from memory
There's lots of different models of Bride seat rails, some are one piece for bottom mount seats or two piece for side mount seats.
Those rails look great! It's interesting to see the difference between the side mount rail you have and the bottom one I ordered, which is a single piece. On the one hand you might think that a single piece is more rigid on side impact but then again when bolted properly to the two piece the seat itself becomes a part of the structure I suppose.
Does yours have a mounting point for the seat belt receptacle?
I hope mine fits and slides ok :) It was $200 posted, second hand. Hopefully it'll arrive tomorrow so I can check things out. Was a hard one to find.
Easier said than done it turns out, I've been trawling the forums to confirm which rails would suit a sedan.
I've tracked down the following Bride rail on sale:
BRIDE bottom mount seat rail type-RO drivers R/H side for NISSAN R34 GTT, W405mm x D260mm/235mm bolt holes
Details off the sticker: Bride Super Seat - Model R34(RWD) - Type RH - Code N105 - Parts list B
> Can anyone confirm if this rail suits an R34 GTT sedan?
I've found two older SAU for sale ads for 4door Bride rails and they had the following details on the (older style) sticker:
Bride - Model R34 - Type RH (T) - Code N105SO - Parts list SN*1
I can't find a clear answer if N105 and N105SO are for coupe and sedan, or whether the N105 is just a newer version of N105SO?!
I got the Bride N105 and I can confirm that it suits an R34 GTT (RWD) sedan. It's good quality, just needs offset plates to suit the Sparco seat.
In hindsight a side mount rail might be better to help go a little lower and allow for tilt adjustment too.
  • 1 month later...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
