ok so last week i decided to wire up my amp and sub.
so i setup the sub without a problem
last night i decided to wire my front speakers (and tweeters) to my amp
so i cut the wire under the dash as it came out of the back of the head unit, so now i had a wire going to each speaker.
so i soldered new wires to them and run it to the boot, plugged it into the amp and .... nothing from the front ...
i just dont see how ive messed it up ... so i decided to turn to the trustworthy people of SAU :(
any ideas
https://www.sau.com.au/forums/topic/326466-front-door-speakers-not-working/
i just dont see how ive messed it up ... so i decided to turn to the trustworthy people of SAU ;)
any ideas
fader from front to rear ? faded to the back not front
wrong wires used?
factory amps? bypass ?
bad crossover wires ?
bad RCA or high level signals
swap the RCA from the sub to the front inputs and see if you have a signal, but be sure to shut off the deck sub out... if it has a crossover built in.
and dont crank it up you just want a sound from them.
could be a lot of things
have you tried to "pop" the speakers from the amp to the doors with a 1.5 volt battery ?, amp not connected?
even with a crossover they will pop when you hit a battery to the wires, with a crossover once the capacitor charges you need to short it out to hear the pop again. PM me for exact details if you don't understand . try not to use anything more then 1.5 volt battery. or it could damage the speakers
I'm assuming your positive you have front speakers in the car ? I've heard that one before.. and found they didn't have any installed..lol
worked it out
my head unit has 'restrictions' on output
would only allow the back to go through the amp enless it was in multifunction mode (only Cds) .... soo i bought a spliter and split the back output and connected the rcas to it and it sounds great
now i have another problem .... my tweeters have a static sound in them when music is played and as i rev the car you can hear the alternator whining -.-
i checked the wires and they dont seem to be over any power cords ..
any ideas ?
You have a ground loop.
Check your amp grounding (especially is it adequate in size, and connected to the body properly).
You running the RCA and power cabling down seperate sides of the car too, right?
Not always the case, if your crossover on the tweeters is too close to a power wire it's picking up A/C ripple.
alternators produce A/C before converting it to D/C a bad alternator can cause it as well
put your ear near other speakers ,does the noise come from all the speakers or just tweets? makes a difference in the fix
the splitter you put in can cause it as well. amp grounds, battery connections dirty, bad engine grounds, computer to close to RCA,the list is huge
some easy reading for you on noise
Noise prevention
and on power in a car
Alternators,batteries, etc
and a site from the GOD of noise reduction, David Navone, I have his big book but you can find it here
Tech Briefs
cheers for the help
i moved my ground wire and now the alternator noise is gone
buttt
still get the static buzz in only the tweeters .... tempting just to unplug the tweeter XD
butt
ill just have to take it all apart and either start from scratch or just try and correct anything thats wrong ...
thanks guys
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
