Bad Handling, How Do You Fix It
Dominic
 Share
I know you have said it was aligned twice but was this done by a laser or by string line?
Last time it was done by Road and Race performance of Rydalmere.
Im still thinking it may be the 15mm spring height difference?
So what would be the best springs to use to replace.
  • Replies 46
Dom is that the same silver item you took me for a wrap in some months ago? (came to buy helmets etc I was the wog).
Perhaps its karma, all those half nekid pics of u in bed with wads of cash LOL
Yes, ive dropped my pants and I definately have a front shaft.
Its very small though!
That explains why you have a GTR :cool:
only joshing.. i'm just jealous... prick.
:D
15mm lower on one corner???!!!!! and yet you are asking about wheel alignment etc?? How if this car is on standard suspension is one corner 15mm lower, further to that what does the VDC etc think is going on when it is already seeing Gs going back and left?? DMS is good, MCA is BETTER. used both on rally cars. Suspension setup and tuning effects a car so much more than you will ever believe. My RS Impreza rally car, with DMS was unreal on one setting, but I felt it could go softer, we took 2 clicks (of 20) out of it, spent the next 2 stages chasing the front on hard pack, then the road would turn muddy and I could not make it go straight, back one click, and heaven!!!
agree. everyone is talking about all sorts of variables but I cant get over the drop on the rear passenger corner, something major wrong there. I wouldn't be investigating wheel or tyre setup until the suspension has been thoroughly inspected. sounds like you are a serious driver so might as well look at a full coilover setup while your at it. Lots of people have gone for JRZ and have had very good results. I have used MCA. good first up results even with suspension being only crudely setup for my first track day on it, much work with tuning to come.
Why keep experimenting and spending the money over and over?
Just take it to Col Crawford Nissan Performance Centre at Brookvale. They are a GT-R dealer, properly
trained and equipped to fix your car and align it to factory street or race specs on a fantastic fully interactive alignment machine
(the only other one like it I saw doing my other car at Marshalls Mercedes in Parramatta, but there may be others out there)
Ask Matt or Steve for advice and they will check your total suspension for any faults.
Before you throw out the factory set up check first what's wrong with it.
BTW, you should be able to go through Turn 1 at EC at 180kph in a stock car, with stock Bridgestones, set on 3 x R with street spec camber, lap after lap, without going sideways and getting a heart attack ! ;)
At this stage I may drop the car into DMS and get them to build a set of coilovers and springs to suit the car being a rally car.
Fair price and much closer.
The car is a JDM unregistered stripped out race car with cage.
Id love to take it to a Nissan dealer but they are so hard up they wont even sell you an oil filter if you have a JDM, lucky the GTR uses the same oil filter as a Ford Telstar/Mazda 626.
Edited by Dominic
that is a good way to go for what you want. but personally I'd try and sort your problem before changing stuff. as you'd hate to carry it over to a new set-up. there is something fundamentally wrong for it to be handling as evil as you say it is.
My concern is there may be a VDC issue causing it rather than springs and wheel alignment, neither of which GTR is 'particularly' sensitive to from a stance viewpoint
But if its sideways everywhere then its pretty much in 2WD.....Regardless we can fix :P
Edited by Martin Donnon
Now I have a bit more time I can advise you of the correct process Dominic.
A normal power run for your car should give you a Torque Split front/rear curve that stays at around 50% the whole way through the run, possibly heading towards a rear split of 60% towards the end. If there is a massive variance in this then you will have a VDC issue. The very first thing to do is read, note, and then clear the codes with your Cobb Accessport. If this does not fix the issue then you potentially have a transmission issue with the front output shaft assy of the GKN magnetic clutch.
I'll say it again, 15mm of negative wedge (which is what you've got with the left rear being 15mmm lower) is HUGE and is going to cause the car to be very loose in left hand turns (T1 at EC). By all means keep looking for driveline problems, but don't overlook the most basic setup problem your car has.
  • 7 months later...
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
