Yeah, its a minter and fairly rare so it'll be staying as is. Does around 30km per month. GTR's are so cheap to run lol.
Geezuz!
Take it out for a drive will ya! ;)
That's like a short drive to the shops and back once per week of the month (4 weeks)...
I guess it being an ADM GTR it has a decent value to it.
  • Replies 43
my rolla is 27 years old and i've only spent around 7 times the redbook value of the car modyfing it :)
and lets not start on the 33 :rofl:
wait... wut.... Throckmorton Scribbledick, you change your oil every thou? :)
Sure, thats every 2 years or so. The car did get driven a fair bit when i was in Darwin but now its pretty much a shed car. Ive put around 2000ks in two years. It will be doing a lot less now.
drive the fucking thing ffs... you dont need a reason do go for a drive y'know.... :)
it's a car that cost about half of what the gtr did 20 years ago, or in perspective, the new gtr costs about the same as what the r32 did (once you take into account inflation, etc), so the sti wrx is about 1/3 the cost, has 2 less cylinders and 100cc smaller engine, and is designed to be something, that when modified, doesn't need to put out 1000hp, but only needs about 350 to 400hp with a buttload of traction and short gear ratios. different horses for different courses.
Yeah this i understand,but i have found so often that WRX drivers are ex-nissan owners that complain about not getting traction etc, so ideally they wanted 1000hp, but when they figured out they couldnt get the power to the ground (or thats its really hard to drive) they traded for less power..This is the gayness..
RBNT man i thought i was slack 6000km in 3 years, but you win..At least your car will be appreciating but.If not now eventually..There will be a boom period like the GTHOs in 20-30 years, if you can wait that long you will cash in fo' shizz
On the subject of ADM R32s, check out this one at Classic Throttle Shop (Nth Sydney),
Was listed at $70K and has just been sold.
http://www.classicthrottleshop.com.au/modernclassic22.html
Good money.
My car is exactly the same as that albeit with 20k more on the clock. Full books, original leather folder, owners manual, alf barbagallo's business card.
It was only on their lot for 3 weeks.
From memory, Wheels Magazine tested back in '91 or '92 it was 4.7 secs, ADM R32 GTR.
I have seen time vary from 4.7 - 5.3 secs.
Depending on the driver I guess...
Yes i know the GTR does im asking about the 2011 STI wrx
They say it will be slightly faster then the hatch back version because it is lighter, but did not give an exact time measurement.
So what ever time the hatch back does, knock off afew micro secs I guess...
Good money.
Yeah, awesome bootlid that doesn't line up....
My 32 was minter =/ (Wasn't ADM though)
Edited by Ten Four
Somewhere slower than an R1 and faster than an Aurion.
Like it makes a toss of difference anyway. Surely there are more important ways to determine a car's performance potential than a single figure (which conveniently happens to be the GTR's strong point)
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
