Installed the light today looks heaps good!!! If you want to get some, dont buy those on thats on ebay they are crap.... bought some a couple months back they are crap!!! These are side firing SMD strip not the coventional one.... I am imported 10m of these light sitting at home if u want some I can sell you some if you are interested. You can PM me for more photos and prices!
Edited by bosco
https://www.sau.com.au/forums/topic/326527-v35-daytime-smd-driving-light/
did u have to remove the plastic cover on the headlight assembly by baking it in the oven?
Nah this smd strip is ultra thin and all u have to do ist stick in on the side of the the headlight, u cant see u the strip its all hidden away! no baking and stuff, these new designed LED strip lights have LEDs shine on the edge instead of facing up, therefore no matter how you flip the strip, the LED lights are always shining towards the front. Also because these are ultra thin, you can easily insert them in the gap between the headlight lamps and bumper, or under the bumper virtually without noticing anything there at all.
how is the glue/3m sticker provided? reason why i asked is that i used one of these before in WA and when the heat came it slowly came off.
it's a premium 3m tape ones, if u clean the headlight well enough it will stick very firmly and won't easily fall off or loosen! All wire are included!
can you pm me for pricing to WA also...i took my old one off...
and to NICKO... how did you manage to get the headlights apart... baking? andy signs of leak when you put it back? ive got a set of angels here bought from the U.S but no one in WA dares to play with them. im planning to get the cincitys design ones pretty soon..
Yep, too easy  :) somebody did it twice and nothing happened. Also you can add some clear sealant if you'd like to be sure that the moisture wont come in.
I spent a long weekend to do that so you have to be very carefull with temperature in a oven and do not use heat gun-blower that's useless.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
