  • 4 months later...
i have just bought an rb25det for a reasonable price an all up it is easy to do it yourself job cheaper aswell but depends on your decision so anways provided you know what ur doing i sold my rb20 for $3.500 an theres nothing wrong with it. If u can always check up on prices and is always helpful to ask i have an r32 gtst and you will porberly need an r33 if u want to add power mods (stupid answer) to it after the engine swap turbogearbox for ya ride but all should be sweat sorry to breif
hope this was helpful
life is what u make of it not how it treats you
$3000 for the RB25DET (just jap)
$1195 for the RB20DET
You'll need a stronger gearbox (RB25) which is about $1000. Optional but recommended to replace the front brakes with R33 brakes as they're slightly bigger (and better).
It'd be cheaper to buy a R33 front cut. Atleast that way you'd have some extra stuff to sell like the headlights and quarter panels. I'm not too sure how much they are as I can't find a price anywhere on the net (not really trying).
Labour? a few slabs if you do it with your mates, you'll learn a lot from it as well.
If you're going to get a mechanic to do it, might cost about $1000 if nothing goes wrong...
I'm in the process at the moment, although my RB25DET is from a Stagea AWD.
The engine set me back $3700 (complete with auto trans! - any one want a AWD auto?), and I'm planning to run a Wolf3Dv4+ ($1600). Then there was a $1G for the lightweight flywheel and clutch setup (which I would have got anyway).
The engine didn't come with a coil ignitor module (its apparently built into the ECU), but I managed to source a reco'd one from Petroject ($350).
Extra couple of hundred for ancilliary stuff like relays and wiring.
I'm hoping to do most of the work myself, just renting space to do the job. So I guess I'm looking at around $6G all up. Plus tuning time (for the Wolf).
If you get a half-cut, it might be a bit cheaper, especially for a RWD-only cut. And you get all the electrics you need, ie ECU and loom.
RB20DETs aren't worth that much, maybe $1G if everything is attached.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
