Hey guys,
Recently replaced my clutch master cylinder with the assistance of this post here:
http://www.skylinesaustralia.com/forums/To...Ma-t126049.html
Fantastic tutorial helped out heaps. I have completely bled the system out and everything is connected back up. Used the following tutorial for that.
http://www.skylinesaustralia.com/forums/Bl...amp;mode=linear
So my issue is I can't tell if there is air in the system or if there is something wrong. Im only getting pressure in about half the pedal. i Cant see/hear/feel any air coming out of the system and I have bled it from the 3 valves that i can find.
The one on the master cylinder, the one on the dampner box and the one on the slave. I have an 89 GTST and from what I can tell in the tutorial there are 4 valves but I can onlu find 3? Wondering if this could be the source of my problem?
Any ideas would be awesome! Cheers :blush:
where is the fourth valve? I have found the one on the master cylinder, the one on the dampener box and the one on the slave... i have followed the line from the master to the dampener and cant find one in between but think this is where im missing one???
I followed the instructions exactly except for the fact that I couldnt find the second bleeder he was talkin about. The one from the master leading to the box. I found the one ON the master, ON the box and ON the slave but none in between. Is it possible that my master cylinder wasn't the problem? I was driving along, I clutched in and I heard a loud pop noise and gear changing was no longer possible. When I clutch in and out at the moment I can see the slave moving but it's not quite enough to fully engage the clutch as I still can't get it into gear.
A good indication if air is still in the line is the pedal sometimes won't return completely from the floor. There are 3 bleed points as you have already found. I use a one man bleeding system which comprises a small bottle and clear tube (can be purchased from SuperCheap, Repco etc). With some fluid in the bottle during the bleed process you can attach the clear tube to a bleed point and open it and pump the pedal as many times as required without the need to open and close the bleed during pedal movements as on the return stroke liquid from the bottle is sucked backwards rather than air being sucked back into the system. The clear tube allows you to see the air bubbles and once they stop you can close an move to the next point. I typically do all 3 points twice to ensure all air is removed.
If the air is out of the system and you still can't engage the clutch you may need to adjust the pedal takeup point. The clutch master cylinder rod is attached to the pedal via a fork. The fork is threaded and its position on the rod can be adjusted by simply screwing it inwards or outwards and thereby adjusting the pedal position when the clutch engages. I have only just had to repair my fork as it stripped the thread and moved inwards (moved closer to the master cylinder) making the clutch engage when the pedal was just off the floor. I subsequently drilled the threaded portion out and welded a nut the back of it and screwed it outwards so now it wont be affected by my very heavy clutch and the clutch now engages when the pedal is halfway off the floor.
Hope this helps.
Ok so for those interested, I have found the source of all my problems. There is a metal bracket that holds the clutch pedal rigid to the firewall. One of the spot welds has popped off meaning there is not enough pressure being put on the master cylinder to enghe te clutch. Effectively the pedal goes a but sideways when pressed in. So, I may have replaced the master cylinder for no reason haha!
ANYWAY, I'm trying to find someone who has a welder I can borrow. The spot that needs welding is tough to access though! Will see how we go.
I had the same issue. Ended up buying a stock second hand one and had it beefed up with extra welding - this way its stronger than a repaired one or a Nismo replacement.
Just remove it to have it welded, there is no space down there. I replaced my master and slave at the same time for peace of mind. Fitting the master was a nightmare and so was bleeding.
I have been looking around and there is a product that panel beaters use by 3M called automix panel bond. I'm thinking of giving this a crack before replacing it completely. It is still in position where it's sitting and from what I understand this stuff is very strong and equivalent to factory welding in most cases. my next problem is going to be getting some as i dont need a massive amount...
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine and drivetrain will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe, give me my power goals I want and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
