Ok just put a 45v2 turbo (rb25 series 2) on to my r32 Rb20 and a 3" front and dump pipe.
Tuner is a idiot and had the boost set at 5psi but still made 2rwkws more than the rb20 turbo at 12psi.
When i got the dyno sheet the AFR starts at 13.5:1 and dumps to 11:1 at around 5500rpm.
the bottom end of the power graph is a bit lazy.
Just wondering apart from getting a new ecu and retuning it, is their any other way of richerning the AFR?
I also have the following.
RS*R 3" cat back
drift pod filter
turbo tech boost controller.
I do wont to run it at 12PSI
https://www.sau.com.au/forums/topic/326549-rb25-turbo-on-rb20-question/
If its the stock ecu, it will richen up as you turn the boost up.
But the question is why do you want it richer? 13:1 when spooling sounds ok and 11:1 on full song is pretty good to be honest.
sounds like its too rich already. turn the boost up and do a power run to make sure its safe.
13:1 and 11:1 too rich? Are you sure?
You might be surprised when asking real tuners their opinion on 12:1 AFRs.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
