I'm in the final stage of my engine transfer, rb20det, just about to get the ecu chipped so thought about getting a new turbo, was thinking of either a vg30 or rb25 turbo, looking to get ppl's throughts on the better of the two, i have the choice between a low km vg30 or a lower km rb25 but also r34 neo turbo for twice the cost. not looking for huge power just a good reliable, put you in the back of the seat, turbo.
what would you buy??
Cheers
https://www.sau.com.au/forums/topic/32655-help-vg30-or-rb25-turbo/
I have no exp. first hand - im a textbook expert (forums are my textbook) but I would go with the rb25 turbo, as I would have thought it would have been less laggy, because I have read in threads of ppl with rb25's upgrading the turbo for a vg30 item to make more power. IIRC they are making 220-230rwkw's on rb25's with the vg30 turbos, where as your rb25 turbo will max out at 180 - 200rwkw.
Sumo
is it true the vg30 turbo exhaust wheel is steel as opposed to ceramic in the rb25 turbo?
if this were the case, you could wind up more boost using that variety.
but i would still say rb25 turbo as it would be a reasonable upgrade and for a 2L car on the street a vg30 turbo lag may be an issue...
Waz.
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
