Pretty Candy Apple Rb26dett Valve Covers
Hi SAU peeps,
Just thought I would share my freshly painted 33 GTR valve covers! It was a freezing day here in Melbourne, so had a few heat lamps going off in the shed keeping me warm and the paint.
3 coats of base (colour)
5 coats of clear
I stuffed up on the timing belt cover (minor run), I will blame the cold weather, not the fact that I tripped on the compressor hose and got a little to close :blush:. Will lightly rub the timing belt cover back next weekend and splash another few coats of colour and clear.
Jason
Even tho' this deserves to be in the "Cosmetic" section, you've done a really great job on these Jason.
Well Done :P !
Wrong section, I see! Excuse me as I am new to SAU. Thanks mate, took me ages in this cold weather, but very happy with the result.
A few minor specs of dust particles, nothing major though!
Edited by OstrichFace2010
That looks sweet as!
I wanted to paint my covers that same color too!
So I assumed you paint stripped the black paint off then went ahead with the spray paint?
What type of paint did you use and what's the colour name?
Yeah I paint stripped them back to bare alloy, thoroughly cleaned them inside and out.
The paint is called Chrysler 'PHZ' Pearl Candy Apple Red. I do not have the paint code though. Quote this name and they should be able to make this up for you. Cost me $50 per 500ml and I didn't even use 250ml.
I wanted to acheive the R34 GTR cover colour, but could not find a paint code for this anywhere, so just went off my sight and this was the outcome. Think I guessed quite well.
Also the paint brand was HiChem.
Yeah awesome man!
Thanks for that.
The colour looks pretty close to the R34 GTR covers, which is what I like.
Welldone!
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
