sorry for asking a silly question but should a coil pack fit tight to the spark plug like a plug lead or a sloppy loose fit? I am asking as this is the first car ive had with this type of coil pack set up and i am unsure if they should fit over the plug tightly or fit loose and rely on the four bolts to hold them in place. i'm sure that my coil packs are stuffed as they are a very sloppy fit on the plugs and the car is missfiring like a bastard .
Edited by gregando
https://www.sau.com.au/forums/topic/326568-rb20-coil-packs/
:D found a couple of posts pretty shore coil packs are stuffed car idles little high but smooth from 2000rpm starts to miss and fart more throttle and gets worse full throttle sounds like subaru am only runnin standed boost with inter cooler any help at all would be much apreciated
https://www.sau.com.au/forums/topic/326568-rb20-coil-packs/#findComment-5316063
If they are loose then yea i'd say they are rooted. Best off getting another set be it some new ones (splitfire, Yellow jackets) or some 2nd hand ones depending on your cashflow. if this has been happening for a while or you just got the car i'd suggest changing the plugs too. Sometimes u will find some clown has left some ancient plugs in it. If this fails to fix it it's time to go talk to someone about testing the igniter it may have a loose / damaged cable and beyond that there is a large bunch of stuff it can be (mostly minor) but time consuming.
https://www.sau.com.au/forums/topic/326568-rb20-coil-packs/#findComment-5323341
    • Ahhh, that, yeah, but it all worked out well in the end As for the ITB noises, I don't really wind it out with her in the car, and the dort only really starts dorting hard when your WOT or up it hard
    • It wasn't about the dollars. I mean how she didn't like the loud exhaust and you had to change it again 😛
    • I'll tell her I put in a new air filter on it, which, it would have anyway with the ITB's In the end she isn't to fussed, she spends lots of money on hair, nails, make-up and all the other "required" beauty products that women use, plus I grease the wheels with shiny gifts and holidays wherever and whenever I can She once questioned my car spending "budget", but after itemising everything she spends on herself, and what I spend on her, and the fact that I don't care if she does or doesn't wear make-up and fancy pants perfume, or requires new outfits for every wedding, funeral or anything else she deems worthy, and I'm quite happy to go "real" camping, instead of staying in hotels or jaunts on cruise ships, she decided not to press the subject on how I spend funds, and has never asked "how much did that cost" again, so a win to me And how often can you say you really get a win with the fairer sex? She is a good woman, and in the big picture, I'm really lucky.....that she hasn't killed me yet
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
