merli, it wouldn't be like your 600kw@wheels dyno sheet would it?? :(
im sure we'd all love to see it make those figures again and again and run the times it should with 2530's and that much power, but that would be the question as to why HKS would rate that turbo kit for 600ps (447kw) @ the engine instead of the 850ish that it'd apparently be good for. Either those are 2835's and not 2530's, or thats just broken a few BS metre's
  • Replies 77
merli, it wouldn't be like your 600kw@wheels dyno sheet would it?? ;)
Exactly :)
The reason I did that was to scan it in to post in threads like this, but I'm scared that people will photochop their details onto the dynosheet and claim it as their own dynosheets on other forums :(
and it was 600.1kw ;)
i dont think its got anything to do with wastegates or the turbos, casue even if you pull the wastegate hose off you can run maybe 25psi max on those low mount turbos, and 25psi wont make that power, it must be a misprint or just maybe it has huge mods thats we cant see.
Guys the dyno is correct,  it has not been edited on photoshop or anything like that.  He is running GT2530 turbos and there is no nos kit on it.
I think for that run of 526 kws they used a massive amount of boost 25+psi  just to break the 500kw barrier.  It is normally setup for 450kws or something like that.
And stacy is the guys girlfriend who the car is registered through.
If u believe that story u must believe anything!!
Are you sure it's not "estimated flywheel power" and not at the wheels? HKSgt2530s will not get 400kW aa all four, let alone >500kW. Some's playing funny-buggers, whether it be dyno operator, photochop artist, or the pic that's been posted is incorrect.
Something just doesn't gel, simple as that.
I have a 13inch penis... Im serious, I have the dyno sheet to prove it. :)
I have to say im very wary of that figure, as i dont believe low mount turbos can bring up real a 500kw +. Unless they tune like rigoli, for one dyno run at 40000 psi boost :(
I hope im proven wrong though.
I have a 13inch penis... Im serious, I have the dyno sheet to prove it. :D
Hey Smoothy,
You may have a 13" penis which was proven on a dyno, God only knows how but 500+rwkw is achievable. Just look Jason's R34 (rh9.com.au) project which never got finished in the end. His car made 500+awkw with a shot of NOS with 2540s which are low mounted...
have a lokk at another funny dyno someone sent me
funny and bored people
I'll never look at a posted dyno sheet or timeslip with any faith again...
I'll also be more careful when signing documents I receive in the mail now that I have seen what nick can do with just a posted dodgy dyno sheet and a computer... Ignorance WAS bliss... Cheers nicknick!
Please People If You Go Back To The Origianly Posted Dyno Sheet, Have A Look At The Numbers On The Left Side, If You Notice That From The Bottom On The End Of Each Number It Starts From 1 And Goes All The Way Up To 9..
Eg 61, 122,183, 244, 305, 366. If You Get What Im Saying Thats The First Time Ever Ive Seen A Dyno Sheet The Has Every Number From 1 To 9 Starting From The Bottom
That's just a coincidence IMHO...
The power scale depends on the scale that the graph is set to. In that case, the dyno operator set it to 610kw, which means that there are 10 increments of 61 each, hence what you see there.
I don't believe that the dyno scan has been tampered with after being digitized, but rather before, whilst it was on the dyno.
edit: either that or the wastegates stuck shut during the run
Hey Smoothy,
Enough about the penis... im proud to say i dont have 13 inches... :D
I agree rh9 does it David, but that is with nos... the graph mentioned was using no nos?
Like I said, id love to know it was true... Because I know id be happy in a low mounted 500kw+ gtr :)
Anyone remember teh official HKS R32 Drag Car ('95)
It ran HKS 2540R x 2, with 290intake/280exhaust with HKS 88mm pistons & rods to punch out 800ps. On slicks i think it actually ran high 8s, mind you the thing was gutted race car, but the engine still used low mount turbos. :(
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
