ok guys, this sound has become apparent since the last oil change (now on roughly 6000kms thanks to Canberra - Melbourne return, doing again this wednesday), or a stack of suspension/steering work I had done at the same time, and only ever happens on a cold engine though it lives outside so is much more likely to do it when I start it in the morning after freezing overnight.
The only thing I can relate the sound to would be the sound you make when sucking the last bit out of a milkshake or thickshake through a straw - you know, the sound you're embarrassed to make sometimes coz it's loud. It appears to be coming from under the front of the car, hence engine.
It is able to be "recreated" as I reverse down my driveway, as it's relatively steep and places the car on quite an incline. Has only done it on one occasion before I've even moved the car, which was this morning, hence why I'm writing this. As I'm reversing down the driveway, when I touch the brakes or bring the car to a stop, this is when the sound occurs. It's as though the car stopping causes whatever is making this sound to move backward through momentum, and do it's thing.
I don't understand the insides of the sump, and how oil pickups etc work, but from an ignorant point of view I have suggested something like the oil moving to the back of the sump as I brake on my driveway....but this has been dismissed (not to mention why does it only happen on a cold engine?)
Whatever's causing this can also be felt through the firewall via my foot on the clutch, so something is definitely vibrating or something.
Mods are only 3.5" turbo back, FMIC, bleed valve @11psi...suspension is bushes bushes bushes, ISC coilovers, rack mounts, front+rear upper camber arms, rear traction, and HICAS lock...though I don't think any of this will be the culprit...
/end wall of text, thanks guys.
https://www.sau.com.au/forums/topic/326594-mysterious-sound-on-cold-start/
Bleed your cooling system and make sure the heater is turned on when you do so and try to do it on a hill so the air moves towards the front of the engine.
Sounds like the water is moving about. It's the sound it will make when air is travelling through the system.
yes, it definitely sounds like air through a liquid system, though what do you mean by "cooling" system? As in, water/radiator etc etc, or aircon?
And if you're correct, this wouldn't be detrimental at all would it? Not causing damage that is
generally wont have harmed your system, as long as engine temps havent been out of control it will be fine.
cooling system refers to water/radiator. when you bleed/flush your cooling system you need to have the heater controls set to hot and turned on so that the cooling system is fully open and you dont trap any air in the heating system. the best way i find to absolutely guarantee no air in the system is to have the radiator cap off, pull off one of the heater hoses on the firewall and place your thumb over the end, then shove a running garden hose into the fitting on the firewall. when the air bubbles stop coming out the top of the radiator, system is bled. should take up to 15secs or so (dont take forever doing this or eventually your anti-freeze will become plain water) quickly remove garden hose and re-attach the heater hose to the fitting on the firewall and replace radiator cap.
this method is yet to fail me.
Edited by jonboy
ah ok, makes sense now ;) since it's going into the shop on wednesday for brake machining/general service, I'll get them to do that too.
Aftermarket gauge has never red more than 90 deg, and will sit on 80 - 85 during normal operation, so overheat definitely hasn't occurred :)
Thanks for the input guys, much appreciated! Will update with results later in the week for future reference
will have to have that looked at too....I've noticed my fluid was low a while back, though it hasn't gone down since I topped it up....
Dropping it off at workshop tonight so they can leave it outside over night and start it when the thing is frozen in the morning, hopefully it makes the same noises and they can work it out.
OH just realised though...it's making a sound before I even touch the wheel, but the main sound is after I've turned it (not directly after, but the steering has moved before I ever notice it)...still reckon the rack is possible?
Mine makes the noise before turning the steering wheel aswell. The power steering pump is driven by a pully off the engine, so if your engine is pumping, so is the power steering pump (whether or not you are turning the wheel or not).
* thats my take on it, someone correct me if I'm wrong.
the pump is turning yes, but the rack itself doesn't receive anything until you turn the wheel....well at least that MY take on it lol.
Either way, at least you've given me something else to suggest when I drop it off...some small part of me wants it to be a big bad monster so I can get the thing built lol...oh I don't know :)
Yeah air in liquid (be it water, power steering pump....even oil, though that's VERY unlikely) seems like the culprit...
And yes Pat, I want to have to rebuild lol, coz upgrades are coming very soon, so I could same some labour cost in the long run by having it built now rather than when it eats shit. I already suspect a bearing on the exhaust cam is on the way out...downside of waiting 'til she pops, is that I could make a big mess.
Mechanic suspects power steering pump. They only heard a faint sound once on first cold start, but nothing afterward.
Ah well, at least they're 99% sure there's nothing bung in the engine, which is fine in my books.
Thanks for the input nonetheless guys :/
Bump.
OK so whether is be coincidence that it has stfu or what, my car has not made this mysterious sound once since the service.
Unless the workshop flushes the water system without telling me (which I doubt, as when there's a highish labour charge, they list everything they did), then the only thing they did that would change anything was an oil+filter change.
Other work done was replace a coilpack (as it developed a miss while they were checking it out - I don't doubt this either) and machine the discs/deglaze pads (front)
So is it coincidence that it resolved itself at the same time, or is it possible this sound had something to do with oil?
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
