Hey guys i want to dial out some understeer on my R33 4 door it has the following fitted
Front camber kit
Castor rods
rear camber kit
rear toe kit
sub frame bushes
whiteline Rear sway bar 22mm set on hard setting
Whiteline Front sway bar 24mm set on medium (cant ajust more need the sperical bearing link kit)
has kyb shocks and lowered springs but changing to HSD HR coilovers
Its not that bad and heaps better then it was before but i just want to balance it so i have even understeer to oversteer or tiny bit more oversteer to understeer ;)
Alinment settings
2.5 front camber
1.25 rear camber
1mm toe rear (2mm total toe)
0 toe front
+5 front castor
Thanks guys
Put the stock front sway bar back on :P
I have only had time to fit my rear sway bar so the front is standard, and boy it oversteers like a whore!! Would be a good drift car haha
Edited by Harey
Yes its a Road car :)
Just some low budget 215 45 R17s on 7.5" rim
running 40psi front little bit better but still bit more understeer than over steer.
i cant set the sway bar softer until i buy a new link kit for the front because the stock links wont reach the softest setting hole on the bar :)
i have picked up some BC racing BR series coilovers i am going to fit these and see if there is any change because i think one of my front shocks is leaking ;)
Those won't help.
i have picked up some BC racing BR series coilovers i am going to fit these and see if there is any change because i think one of my front shocks is leaking :wub:
Those will probably make it worse. Stiffening the front end will only increase the understeer characteristics.
i am just saving up for some Federal 595's or some KU36's for the front, its already on the hard setting on the rear so i cant go any stiffer than that.
my lowered springs are about 1.5 inches lower at the front then the rear and the rear have a softer spring rate would have affect it?
Yes softer rear suspension will contribute to understeer.
I would recommend you put on Bilstein shocks at the front if your current ones are buggered. As said previously, stiff coilovers will just make it understeer more.
Plus stiffen up your rear suspension, eg stiffer rear springs.
Edited by Harey
Less rear spring actually makes a car gradually oversteer as opposed to to much spring which makes it snap oversteer.
Too much front spring will cause understeer, but usually mid corner not entry.
If we are talking about a road car and your complaing of understeer, go buy some GOOD tires and watch the problem disapear. You could not possibly be pushing the car into a window where sway bars and springs are going to effect the handling if the tires are budget........
Yeah better tyres are a priority at this stage just deciding on wheels before forking out for tyres.
its good on the street but poped up when i took the car drifting at driving sports event, i am fitting up the coilovers because the car setup i thought was to soft and felt a bit boaty trying to follow through to the next corner.
once i get better front tyres do you guys think i should increase front or decrease front camber?
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
