he denham ill take 2 injectors off ya hands
need them for my custom plenum
U sure u dont want all 6??
SIR33
Clutch is in alright condition. It held 180rwkw with to much hassel.
I can post pics but no until the weekend as its all packed away coz we are moving in 3 days.
  • 1 month later...
Any chance you'll take $100 for them. I am looking for a cheap set to get me by until I get some bigger ones down the track. If anyone has a good set they are wanting to let go cheap let me know.
Guest INASNT
I will let em go for $120 if u direct deposit into my account and i will mail it to you. Its the easiest and quickest way. PM me for details.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
