Ok so I got my car running again after re-fitting the head. Im just trying to set the base timing on the cas.
Just have a quick question regarding the marks on the harmonic balancer
I plugged my laptop into my vipec ecu and it tells me the base timing should be set at 20 degrees.
On my harmonic balancer there are 7 slots.
If standing in front of the car looking down on the balancer, reading the slots from left to right - is the first slot 0 degrees?
Like this?
slots- I I I I I I I
degrees- 0 5 10 15 20 25 30
https://www.sau.com.au/forums/topic/326654-rb26-timing-marks/
If youve got a good timing light and nothings changed with the setup (compression, boost, cams etc etc etc) set it to 20, why mess around?...
Yeah nothings changed except running standard coil packs as my split fires got stolen.
I just set the timing with a $1000 digital snap on timing light at 20 degrees but the car has a bloody ignition miss most likely a dud coil
  • 1 year later...
