hi every one i just moved to vic a couple of weeks back and saw this silver r34 gtr kicking round have been told the guys name is David and the rego plate is WIW590 was wondering if any one knew where he lives or his number as iam looking for a silver 34gtr to be in our wedding photos as we have a 32 and 33 gtr's in silver would like his 34 if he would do it
any help would be grate thanks guys
https://www.sau.com.au/forums/topic/326660-looking-for/
is it gtr 34 after gtr and 35 would be good if i could find one realy liked the 34 i saw hope i can find it or see him out agane and pull him over
LOL, I can imagine the GTR boosting away as you try and pull him over, thinking you are gonna car jack him xD
https://www.sau.com.au/forums/topic/326660-looking-for/#findComment-5318556
Looking for a guy with a white r35 gtr. Rego plates RMODE. Anyone know where he lives? Anyone know what time he goes to bed and whether he leaves the keys besides a window. Oh and does he have a gun (totally irrelevant question but would like to know :P
Cheers people!
https://www.sau.com.au/forums/topic/326660-looking-for/#findComment-5323590
i dont think its suss, it would be a cool pic to have a 32,33 and 34 gtr in silver together.
lol of course it would, but theres plenty of nice silver gtrs on here he could just ask instead. bit odd that hes after his address....
Edited by Jesss14
https://www.sau.com.au/forums/topic/326660-looking-for/#findComment-5323594
Hey Mate I'm the owner off the GTR34 nur. My mate Bez sent me a link for your msg. You Can add me on face book. My user name Is David John Montgomery. My dp is my gtr. As I don't want my mobile number on er. Cheers Mate
https://www.sau.com.au/forums/topic/326660-looking-for/#findComment-5324216
Looking for a guy with a white r35 gtr. Rego plates RMODE. Anyone know where he lives? Anyone know what time he goes to bed and whether he leaves the keys besides a window. Oh and does he have a gun (totally irrelevant question but would like to know :)
Cheers people!
Yep - I know the answers to all of those questions.... :)
https://www.sau.com.au/forums/topic/326660-looking-for/#findComment-5324228
well well well there you go, nur is a bit different
should stop being so sus about people :P
lol was nothing wrong about being suss. could be anyone you know. always gotta take precaution :)
Monty about time u logged on to SAU
https://www.sau.com.au/forums/topic/326660-looking-for/#findComment-5325165
lol was nothing wrong about being suss. could be anyone you know. always gotta take precaution :blink:
Haha Bez yeah true that. Good luck to any1 that trys to still my car lol.
Ey Chris when are you going ti give me a run?????????????????????????
https://www.sau.com.au/forums/topic/326660-looking-for/#findComment-5325426
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
