I got the following parts for sale
Item 1:
Pulled out of
R32 GTS4. aftermarket shocks and kings springs in excellent condition
Price and Condition: $60
Contact Details: Pm me here in SAU or email me on [email protected]
Delivery & Conditions: Pick up only (Can be posted @ buyers expenses)
Item condition : Used
Item 2:
Door trims came off R32 GTS4, will fit R32 GTS and GTS-T. It has some marks as shown in the pictures and both trims have 1 hole each to suit a tweeter install
Price and Condition: $30 pair,ONO (will not sell separate)
Item 3
Used: Autometer Boost Gauge Sport Comp Mechanical with Auto Meter Gauge Cup (Black)
Vaccum/Boost Product # 3401
Size 2 5/8" (66.7mm) Type: Mechanical
Range 30 In. Hg.-Vac/20 PS
And also a 2 5/8" Auto meter Gauge cup (in black)
Note: Boost gauge dont come with the hose but has the cables for the bulb of the gauge, Good condition as it was on my Skyline working fine.
In ebay they selling the gauge alone for $99 no postage
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...IT#ht_500wt_928
and the gauge cups for $29 no postage
so grab a bargain, why buy a new one? if a used one works excatly the same.
Price and Condition: $60 for both gauge and cups
Item 4
FORD 4 Channel Amplifier
Price and Condition: $50 ono
Item 5
Soundstream 2channel Amplifier
GREAT LITTLE TWO CHANNEL AMP WITH PLENTY OF GRUNT THAT CAN EITHER RUN SOME FRONTS OR REARS OR CAN BE BRIDGED UP AND RUN A SUB AND AT THIS PRICE CAN'T BE OVERLOOKED.
HERES THE SPECS
Max Power @2ohm 420w
RMS @4ohm 80x2ch
RMS @2ohm 95x2ch
Bridged RMS 195w
Soundstream SPA-1002 420w 2ch Amp
Features :
-Full Mosfet Power Supply
-PWM Circuitry.
-Full Selectable Crossover Hi/Full/Low
-Three Way Protection Circuit
-2ohm Stable Stereo
-Tri-Mode Capable
-Variable Low Pass 40Hz-250Hz
-Variable Hi Pass 150Hz-1.5Khz
-S/N Ratio:98 db
-System Distress Indicator
-High/Low Level inputs With Floating ground
-Spade Terminals
-Top Chrome Plate
-Platinum RCA Connectors
-Line output.
RRP $299
link is here :http://www.trademe.co.nz/Trade-Me-Motors/Car-stereos/Amplifiers/2-channel/auction-280819226.htm
Price and Condition: $120 ono
Item 6
BOSS AUDIO CAP2B 2 FARAD CAPACITOR WITH DIGITAL DISPLAY (Near New)
When heavy bass notes in your music hit, the current demand on your system greatly increases and could cause voltage drops. This stiffening capacitor acts as a power reservoir, instantaneously supplying added power to keep your system playing strong.
-2.0 Farad Digital Capacitor
-Colour: Black
-Digital voltage level display
-Chrome finish terminals
-Includes mounting brackets
-20V DC
-24V Surge
-Dimensions (without mounting brackets): 10-1/2"L x 3"W x 3-1/4"H (laid flat)
Mounting Bracket is included. What you see on the picture is what you get.
CAPACITOR WEIGHS AROUND 2kg
This is $120 RRP, For you only
$70 why buy a brand new if works the same.
Item condition : Used (Near new condition)
Used APEXi AFC Neo Piggy Back ECU
Reason of selling: Chipped ECU
Condition: Good condition
Description:
The SAFC NEO marks the newest edition to the world famous Super AFC line of piggy back fuel controllers. Building upon the powerful SAFC II, the AFC NEO has taken piggy back style fuel control to a new level. The AFC NEO boasts an incredible 16 points of user definable fuel correction. VTEC control has also been incorporated for Honda/Acura applications. A complete monitor mode is also available to keep the driver/tuner informed of critical engine data.
Features include:
Completely new case design
Compact design
Incorporates both AFC and VAFC functions in one unit
16 point fuel correction
Color FED display
User defined button and background colors
Inverted "anti-glare" screen
Key functions include:
MONITOR MODE-
RPM
Throttle
Battery voltage
Correction %
Air flow %
Pressure
Karmann
VTEC
SETTING MODE-
Air map
Air map graph
Throttle point
Deceleration air
VTEC control
VTEC unmatch
ETC MODE-
Model select
Mode select
Car select
Sensor select
Analog scale
Warning set
Display set
Sensor check
CONCEPT:
High resolution fuel control with integrated VTEC control.
CHARACTERISTICS:
Revolutionary color FED display easily customized by the user.
RRP:$800 SAU members $300
Reference:
-http://www.apexi-usa.com/products/?id=5347
-http://www.modyourcar.com.au/apexi-afcneo-p5022
Pics Below:
Price and Price Condition: $300
Contact Details:PM here in SAU or email me on
[email protected]
Delivery & Conditions: Pickup only/Can be posted at buyers expenses
Item Condition: Used
https://www.sau.com.au/forums/topic/326662-r32-partsampsshockstrimsecugauge/
is it all 4 shocks and springs or just the pair??
interested if set of 4.
hi,
the rear shocks are in full set
but the front only has the struts without springs, i will throw that one for free..
let me know if ur keen
cheers
oh and if they are fronts will you seperate and sell just the shock? willing to pay the same amount
hi,
I do have the front, without springs,
they are same brand of that yellow one
the front one i have without spring
its pedders front shock/strut
let me know if ur keen on this one
cheers
i hav sent u a pm
