Hey guys,
Lots of parts for sale come have a look. Located in Sutherland NSW.
Engine and gearbox (attached, with exedy cushioned button) - 1400
Gunmetal grey bonnet ( small dent in the front) - 100
Black bootlid (10cm scratch in the middle, comes with wing not attached) - 150
Dash pad (wrapped in red vinyl, excellent nick) - 200
Front headlights (series 2 type) - 100 ea
Taillights - 50 ea
Front brake calipers - 250 pair
Front hub/upright/lower/top control arms - 300 ea
Speedo (red backing) - 100
Steering rack/Front cross member - 400
Washer bottle - 40
Radiator bottle - 40
Prices are negotiable and pick-up is highly preferred.
Cheers
Stephen
https://www.sau.com.au/forums/topic/326679-syd-r32-gts-t-parts/
Hi do you have any indicators for the r32 thanks mate
Mate would you take 900 for motor and box, i can pick up next weekend and have cash. How many KM's on the engine and is that complete with everything? my number is 0447461636 give me a call so we can chat and organise something
Cheers
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
