ive just had the 2nd rear 2860-7 turbo fail in my gtr in 6 months. both failures have happened at track days. the turbos have been running 20psi with a good tune.
the turbo shop said the first failure was due to an overspeed. there were no signs of oil starvation.. just the shaft was bent. this was a 4 year old turbo with about 6000km on it.
i havent pulled it apart after this second failure, but i can hear wheels scraping on housings. this turbo had done 600km.
both times the engine has escaped unscathed.
the only thing i can link between the 2 failures is the boost gauge hose popping off the fitting at the back of the throttles.
is it possible that that little fitting could be leaking enough air to overspeed the turbo? this is frustrating :cool:
Steve.
https://www.sau.com.au/forums/topic/326683-thoughts-on-turbo-failure/
If you had a reasonable boost leak you could have possibly over boosted the turbos, although I doubt one event would kill it so quick.
I would be going over as much as I can. What dumps/exhaust are you running?
Well I don't think they can over speed on 20psi. How ever can fail due to oil contamination which wears bearings, increase tolerance, resulting in shaft play and vibration at high speed. Wheel contact occurs once shaft movement exceed its housing clearance. At high speed it breaks both wheels and bend turbine shaft.
Or if you don't have a BOV high surge pressure can also twist the shaft.
Are you sure both actuators are good and moving in unison? If they're not you could be spinning one turbo a lot harder. Even if they appear to be ok, swap the front and rear so if it goes again it will be interesting if the failure moves with the actuator or not.
good advice.. i will check this closely :cool:
trust split dump/front pipes.. high flow cat, and a greddy PEII exhaust.. no blockages.
no other leaks in the intake that im aware of.. it was holding 20psi very nicely before the incident.
What sort of power is ur gtr making?
U sure ur not just pushing them too hard and hence durability is suffering?
Seen a pair of -7s last barely 5000km on a gtr making 330+awkw, and yes this was at about 20psi or so as well. But im talking just getting smokey and losing efficiency, not physically bent shafts or anything of that nature, well nothing easily audible anyway.
last time it was dynoed was several years ago.. it made about 300rwkw (4wd disabled)
and, ive just pulled the intakes off.. looks like both of them are failed. the front is worse than the rear. the bearings are noisy as hell, and the wheel is hitting the housing on the front one :P
Edited by steve_gts4
If there was oil contamination and lack of flow the bearings should be burnt, and have blue markings on them.
I would get them looked at before going further.
Where is you boost reference being taken from? Turbo or plenum?
Could be you have an intake restriction or similar and the turbos are thumping 25psi+ while you are only seeing 20psi @ the intake
U running a catch can?
I agree with Stao oil contamination. Might be due to a little bit of blow bye letting fuel into the oil and breaking the oil down
did the new turbo come with a new actuator?
the engine is pretty new and the rings have sealed well.. it has a catch can which is still empty after 4 years
one actuator was replaced last time.. it had a small leak, and the other inspected and declared ok.
good point.. boost reference is off the plenum. i might move that around the other side closer to the turbos.. would make sense.
i will strip the turbos down myself this time and see what they look like inside.
Sorry to hear Steve, you finally get it all on the road and this happens :(
thanks for the sympathy hehe thats life i guess.. ill work it out eventually :(
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
