fubar Posted June 28, 2010 Share Posted June 28, 2010 Bee-r revlimiter hardly used, in my car for fun and launch control. All works perfect, comes with crazy illustrated jap instructions and all ecu print outs. $300 posted anywhere in aust Standard injectors (blue) out of my rb25det neo motor (apparently 450cc) working fine, the motor had done 60 00kms. injectors also come with elec plugs attached and some wire hanging out to solder onto if you want to custom:) injectors $250 or $400 for intake, rail and injectors Aluminum twin wing black 1400mm long by 250mm wide $150 R32 random parts Roll cage just the front section. suit a 2 door 32 without a sunroof $250 Cusco front camber arms. fixed 4 degrees of camber rubbers perfect condition $150 Rear camber arms standard $50 Stock black boot lid with standard spoiler. clear coat is starting to fade. $50 Air con. from fire wall forward all lines, compressor (off a neo motor) and brackets, condenser. working perfect before removal for de-weighting $200 Set of lowered Eibach spring and kyb shocks no oil leaks. Done less than 4000kms and shocks look like they have some sorta adjustment at the top $350 Koyo aluminum radiator one core is damaged leaking $100 4 rims similar looking to r33 rims and tyres, pcw 5 spoke 16x7 5x114. 2 tyres 50% and 2 60% $150 4 stock r33 rims and tyres 60% tread left on 2 and other on the wear line $250 Come with 6 spare 16 inch tyres:) All parts located in Perth, postage can be arranged for some items at buyers expense pm or 0434 313 923 can post pics of other parts if required Link to comment https://www.sau.com.au/forums/topic/326718-bee-r-rev-limiter-r32-cusco-camber-ams-lowered-springsshocks-roll-cage-front-ac-wings-rimstyres/ Share on other sites More sharing options...
fubar Posted July 4, 2010 Author Share Posted July 4, 2010 make an offer all prices negotiable Link to comment https://www.sau.com.au/forums/topic/326718-bee-r-rev-limiter-r32-cusco-camber-ams-lowered-springsshocks-roll-cage-front-ac-wings-rimstyres/#findComment-5327615 Share on other sites More sharing options...
jrm Posted July 4, 2010 Share Posted July 4, 2010 Standard RB25 injectors are 370cc afaik? Link to comment https://www.sau.com.au/forums/topic/326718-bee-r-rev-limiter-r32-cusco-camber-ams-lowered-springsshocks-roll-cage-front-ac-wings-rimstyres/#findComment-5327697 Share on other sites More sharing options...
8110 Posted July 4, 2010 Share Posted July 4, 2010 Yea those injectors should be 370cc. Link to comment https://www.sau.com.au/forums/topic/326718-bee-r-rev-limiter-r32-cusco-camber-ams-lowered-springsshocks-roll-cage-front-ac-wings-rimstyres/#findComment-5327702 Share on other sites More sharing options...
fubar Posted July 5, 2010 Author Share Posted July 5, 2010 Yea those injectors should be 370cc. Ok fair enough im not sure then cause i was told that they were 450cc but word of mouth always different. I'll give nissan a call. Anyway there out of a neo motor, blue in colour and for sale:) Link to comment https://www.sau.com.au/forums/topic/326718-bee-r-rev-limiter-r32-cusco-camber-ams-lowered-springsshocks-roll-cage-front-ac-wings-rimstyres/#findComment-5329773 Share on other sites More sharing options...
icyblitz Posted July 11, 2010 Share Posted July 11, 2010 bump Link to comment https://www.sau.com.au/forums/topic/326718-bee-r-rev-limiter-r32-cusco-camber-ams-lowered-springsshocks-roll-cage-front-ac-wings-rimstyres/#findComment-5340625 Share on other sites More sharing options...
RBLUV Posted July 11, 2010 Share Posted July 11, 2010 got pics of the camber arms Link to comment https://www.sau.com.au/forums/topic/326718-bee-r-rev-limiter-r32-cusco-camber-ams-lowered-springsshocks-roll-cage-front-ac-wings-rimstyres/#findComment-5340644 Share on other sites More sharing options...
