  • Replies 47
Oh well.... Soon we'll just be left with 4 wheels with tyres...
I see one problem here...
that's a really bad hairstyle.....
Some TE37s will fix that...
Seriously - what about the hundreds of cars (including Australian and Euro) out there with factory privacy glass for the back....
They only pick on window tints because they can't see if you or your passengers are wearing seat belts.
But then again, if you're not wearing one, you're kind of asking to be picked on imo...
That and it makes it hard to see if your on your mobile...Which most people are..
I think privacy glass is fine, eg for the R34. Just not tint. Can anyone confirm that?
First exhaust, now tinted windows. What's next on their list? Cars with 4 wheels and bikes with 2 wheels? Or maybe they'll start forcing people to wear a helmet while driving.
Not long ago, can't remember if there was a thread posted on here or not, there was an announcement you could be fined for leaving your car unlocked because it promotes car theft.
Could still defect on wheels not being factory, tyres not enough tread...and that's before they inspect the engine bay...
Don't know how people can't see through tinted windows, especially at night time when everything that should be on the road should have lights on. Hell, I've worn sunglasses at sundown before and had no issue seeing non-lit objects. And my vision is shit! Far from 20/20. Here are some scary words:
SCAPEGOAT
REVENUE
I can't see sweet fk all out my back window at night time. You obviously have never driven in a car with 5% tint. :P
I think my rear window does have 5% tint...but...I can still see lights through it, which is what matters. If someone does not have their lights on at night time, albeit harder to prove, they are in the wrong. If I'm reversing at night I tend to stick my head out the window and reverse very slowly.
BAHAHAHHA @ this. i heard this few days ago from a mates dad whos a cop.. stupid and funny at the same time. i sold my celsior. i hope the cops are alright with the tint on it i sold.. LOL
hey guys i work for a company that tints cars, privacy glass is all legal as long as the car came out standard from factory although the front two windows wont have privacy glass so its gets matched with 20% (or 20 grade) tint which is illegal, the darkest legal tint is 35% then 20% that illegal then goes down more and more 5% is limo tint cant see in pretty much, same goes with mirror tint its illegal, its not the factor that cops cant see u do stuff in ur car a lot of car crashes do happen with illegal tint imagine driving at night with 5% (limo tint) at night u cant see in and cant see out i no this for a fact
hope this clears it all up for ya's
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
